It is currently Sat Oct 11, 2025 11:45 pm
 Post subject: Exhaust kits
PostPosted: Mon Mar 22, 2010 12:23 am
Does anyone know of any good exhaust kits that will fit a 2000 bonne SSEi? I'm looking to start doing performance upgrades and I figured I'd start with the cheaper upgrades and then move up in the engine.
 Post subject: Re: Exhaust kits
PostPosted: Mon Mar 22, 2010 12:37 am
There are no 'kits'.
A downpipe and larger cat would help though. Nothing to be gained by replacing any other piping or mufflers.
Something along the lines of this:
http://www.3800performance.com/Merchant ... t_Count=14
PostPosted: Mon Mar 22, 2010 12:42 am
Oh ok, I was also looking to gain a different sound, if there are any parts that would add a deeper sound in the exhaust system, please do link if possible, thanks!
PostPosted: Mon Mar 22, 2010 1:35 am
Are you looking for performance upgrades or a sound upgrade? You will never get the V8 rumble out of a V6. There are some on here that have changed the sound of their exhaust, but a lot of it depends on what your tastes are.
PostPosted: Mon Mar 22, 2010 1:50 am
The downpipe and cat will change the tone of your exhaust, and won't be wasted performance like mufflers would be. Do the cat and downpipe first, then decide if you want to change the mufflers for the sound.
PostPosted: Mon Mar 22, 2010 2:42 am
Sounds like a plan Will, and is that the exact down pipe that you linked be the one I need?
PostPosted: Mon Mar 22, 2010 10:26 am
There are several big and small names out there for options. The Series 1 downpipe from the factory is free-flowing, so I'm not your expert on sources for the S2. Others will chime in.
PostPosted: Mon Mar 22, 2010 9:49 pm
I have a ZZP stainless 3" (outside diameter) Downpipe waiting for a high flow cat and installation. Seems like a very high quality part.
PostPosted: Mon Mar 22, 2010 11:16 pm
For an idea of what you're looking at in sound difference, I've got the same 3" ZZP downpipe as 00Beast with a 3" magnaflow cat and a ZZP PLog (Which they seem to be out of stock right now) on and otherwise stock exhaust. The sound gained a noticeably deeper tone and a little more rumble but it wasn't any louder than before.
Here's a video of mine for a bit of reference. The intake almost drowns out the exhaust sound in the first part. It sounds different and better in person, but you can get an idea from the video.
Bonneville SSEi Exhaust Before & After
PostPosted: Mon Mar 22, 2010 11:34 pm
Year and Trim: 2012 Eco
^ His car does sound pretty sweet in person. I've only heard it at low RPM, but it's still nice.
PostPosted: Sat Jun 05, 2010 8:15 pm
To comment on: it sounds best with the manifold open! So ultimately, what do we need to do to get them to sound that way? I have searched and seen all sorts of different combos and setups. But really the best sound i have heard is when the manifolds are either left open or the pipes off. I've seen peeps do Magnaflows. Thrushes. Cat backs. Upping the pipe diameter. And either removing or reinstalling the resonators. But ultimately, what gives the Bonnies the deepest loudest rumble? You know, 60s muscle car rumble. At least that we can acquire with 6 cylinders.
PostPosted: Sat Jun 05, 2010 8:55 pm
If that's your cup of tea, fine. But for most here, that's a horribly annoying sound we'd rather not have on our daily driver. Especially when it hurts performance, which a wide-open exhaust will.
PostPosted: Sat Jun 05, 2010 9:00 pm
Hey hey. Back it up. I don't want it hurtin' perfo. Perhaps i shoulda specified that. I don't want it THAT wide open. But i did think the open manifold sounded good. Not "horribly annoying" to me. I ain't as old as my car makes me look, but old enough to remember what strong cars should sound like.
PostPosted: Sun Jun 06, 2010 10:24 am
Try driving it that way. It'll sound worse! I have an electric servo exhaust cutout right before the cat. It only sounds good at 4k. Nothing under, nothing over.
PostPosted: Sun Jun 06, 2010 11:33 am
I have modified my exhaust a little at a time over the years.
It is a bit extreme right now.
The best sounding performance mod has to be headers. Also the most expensive.
The 123456 firing order of these V6 engines will NEVER sound as good as a V8, even with the best mufflers.
Keep your stock mufflers. The biggest improvements occur the closer you modify to the outlet of the exhaust valve.
PostPosted: Sun Jun 06, 2010 1:25 pm
To get a real burbly exhaust note you need them futher up the exhaust system, not really possible on our cars, Another way is headers. S2 and S1 have distinct sounds just because of the different exhaust vale spacing, and some to do with manifold design.
There are no new unread posts for this topic. Shift Kits
deano55
Thu May 03, 2012 8:07 pm
RogueSSEi View the latest post
There are no new unread posts for this topic. Oil Pressure Kits
Allmachtige
24
3225
Mon May 18, 2009 9:14 am
1994se View the latest post
There are no new unread posts for this topic. shift kits
02ssei
12
4444
Tue May 10, 2011 8:44 pm
There are no new unread posts for this topic. Shift Kits...
ZLTFUL
Wed Mar 23, 2011 6:21 pm
There are no new unread posts for this topic. gear ratio kits
MadMike
Mon Aug 02, 2010 2:21 pm
