It is currently Tue Sep 30, 2025 10:57 pm
 Post subject: heater hose?
PostPosted: Tue Apr 06, 2010 6:06 pm
1992 Bonneville SSEi (Sold)
I just want to make sure I have the cooling hoses right the heater hoses the come out of the fire witch goes where. I have it the top hose in the waterpump and the bottom one in the intake...is that right?
Thanks keith
2001 SSEi Bumbles
 Post subject: Re: heater hose?
PostPosted: Tue Apr 06, 2010 9:30 pm
Year and Trim: 1995 SSei
1987 GN 16K Original
99.9% sure you are correct. The outer hose that is bolted up under the alternator on the bracket should go into the LIM, and the one behind the bolted bracket should be into the water pump.
PostPosted: Tue Apr 06, 2010 11:02 pm
Mine are both bolted to the same stud at the bottom right of the alternator. I have 2 rubber heater hoses coming from the fire wall that go in to same size metal hose. Im kinda lost on what your are talking about.
2001 SSEi Bumbles
PostPosted: Wed Apr 07, 2010 7:26 pm
Thats the bolt I have mentioned,
There are no new unread posts for this topic. Heater Hose Clamps
Madcarpenter
Mon Apr 16, 2012 7:32 pm
kchawg79121 View the latest post
There are no new unread posts for this topic. Heater Hose Adapter leaking
Boreas
Fri Nov 08, 2013 1:04 pm
Boreas View the latest post
There are no new unread posts for this topic. Heater Hose o-rings and Plugs
98buicklesabre
Mon May 02, 2011 11:36 pm
98buicklesabre View the latest post
There are no new unread posts for this topic. Heater Hose Fitting O-ring - Stumped!
96LSS
Wed Feb 02, 2011 10:51 pm
There are no new unread posts for this topic. Leaking coolant from heater hose fittings?
Boosted_GR33K
Wed Aug 14, 2013 4:26 am
Boosted_GR33K View the latest post
Users browsing this forum: No registered users and 18 guests
