It is currently Tue Sep 30, 2025 10:56 pm
 Post subject: Heater Hose Clamps
PostPosted: Sun Apr 08, 2012 9:31 pm
Location: Portland, OR... Nine months of rain per year, yet wicked expensive tap water...
Year and Trim: 1995 SE
So I planned to use the first totally warm, dry day of the year here today to work on the coolant system of my wife's '95 SE 'Green Grocery Getter'.
System flush, drilled 180* thermostat, pressure release radiator cap, new upper/lower radiator and heater hoses, replace the cracked overflow reservoir, new coolant, and upper coolant elbow.
I got nearly everything done, until I ran up against the 'Corbin' clamps holding the original heater hoses to the heater core. I was able to remove all of the other clamps with ChannelLock water pump pliers, but there's just not enough room back there to get them in between the firewall and A/C components, and manipulate the factory installed clamps off.
I've been working on my own cars for thirty years, and have somehow managed to avoid investing in a set of these clamp removers. What do you guys use? Do I really need to buy the remote cable actuated ratcheting version for $50, or will a cheap pair of $10 Corbin pliers be able to angle in there to get those clamps off?
And do you continue to use the original Corbin clamps on your new hoses, or would it be better to install some approrpriately sized stainless steel worm drive hose clamps with the new hoses? (I always assumed the Corbins from the factory wore out after ten or twenty years of service, and have usually replaced 'em.)
 Post subject: Re: Heater Hose Clamps
PostPosted: Mon Apr 09, 2012 4:31 am
If you want to get the clamps off without possibly damaging the heater core, you will need the tool. Not saying that it will save the heater core, because trying to get the hoses off may just kill it, but.....you will need this tool again, trust me.
As far as the clamps go, I re-use them if they are not damaged. If you can actually get to the drives on the worm-drive clamps, I say use them, but do not over-tighten!
PostPosted: Mon Apr 09, 2012 7:19 am
Basically there is no way around it, you must have the cable actuated pliers. I found mine locally for about $30, so look around and check online before dropping $50 on them.
To be honest though, I wouldn't even worry about replacing those hoses. I have never seen anyone have an issue with them blowing out or blocking flow from going bad.
I replaced the heater core in my old 93 and reused the clamps without issue.
PostPosted: Mon Apr 09, 2012 11:28 am
Well good news then! I figured if you replaced upper and lower radiator hoses, might as well do 'em all...
I'll just save the spare new heater hoses I bought, and wait to buy the $50 clamp remover until I really need it.
Re: taking the hoses off the heater core stubs: If I can somehow squirt some Kroil in between the hose and the core, would that lessen the chance of breaking the solder joints? Or how about maybe trying to surgically slice through the top of the hose with a utility knife, to help peel it away?
Thanks for your replies.
PostPosted: Mon Apr 16, 2012 7:32 pm
Year and Trim: 1994 SSEi
I always use a utility knife to slice through heater hoses I won't be re-using.
There are no new unread posts for this topic. heater hose?
irish91983
Wed Apr 07, 2010 7:26 pm
tripscarcare95 View the latest post
There are no new unread posts for this topic. Heater Hose Adapter leaking
Boreas
Fri Nov 08, 2013 1:04 pm
Boreas View the latest post
There are no new unread posts for this topic. Heater Hose o-rings and Plugs
98buicklesabre
Mon May 02, 2011 11:36 pm
98buicklesabre View the latest post
There are no new unread posts for this topic. Heater Hose Fitting O-ring - Stumped!
96LSS
Wed Feb 02, 2011 10:51 pm
There are no new unread posts for this topic. Leaking coolant from heater hose fittings?
Boosted_GR33K
Wed Aug 14, 2013 4:26 am
Boosted_GR33K View the latest post
Users browsing this forum: No registered users and 14 guests
