It is currently Thu Sep 25, 2025 1:37 pm
PostPosted: Sun May 03, 2015 8:38 am
Year and Trim: 2004 Buick Lesabre Limited
Gran Touring package
Hi guys, I went to change the leaking return line fitting on my transmission on my 2004 buick lesabre and the new fitting was completely different. I bought the dorman version of what is supposed to be 04+ models with 9/16-18 thread. The threads sorta looked a bit bigger than the old one and wouldn't thread on.
Heres a pic
Also none of the rockauto suggested fittings are long like the one in my tranny. Any ideas? Thanks
PostPosted: Tue May 05, 2015 11:48 am
hi, I would first try some loc-tight on the original fitting and see if it stops the leak-- worked on my 93 cutlass
PostPosted: Tue May 05, 2015 11:55 am
Try a fitting for a 2003. When I replaced mine, they were the correct short size.
PostPosted: Tue May 05, 2015 10:40 pm
One of the fittings at trans has a ball check in it and other doesn't.
I think Dorman only sells the one without.
Delco part number I used was 24213958 for the one with check ball.
Dorman # for other was 800-605 (which is different from what you are showing).
PostPosted: Sat Nov 14, 2015 2:45 pm
Been a while but as original poster thought I'd check back in to share what I did.
It turns out the threads on my transmission for the return line are 1/4-18 and I bought a 3/8-18 fitting. I chose the 3/8-18 because my car is a 2004, because 2004 and up used 3/8-18, but really they were using 1/4-18 on the return line into January 2004; so my car must have been built in early January 2004.
So I replaced the o-ring on my original fitting with the one on the new fitting I bought to stop the leak.
There are no new unread posts for this topic. Upper trans cooler line leaking at fitting
raa1144
Sun Jan 01, 2012 8:33 am
There are no new unread posts for this topic. Transmission external cooler fitting help at 4t65e Please
Kevdadi
Thu Apr 18, 2019 8:13 am
96 SSEi View the latest post
There are no new unread posts for this topic. 03 SSEi Trans cooler line NOT 3/8 NPT
Mon May 23, 2011 9:26 am
Jrs3800 View the latest post
There are no new unread posts for this topic. Transmission cooler line connectors
GerGa
Mon Jan 15, 2018 8:23 am
maxi426 View the latest post
There are no new unread posts for this topic. Vac fitting restoration
spoiledred94
Fri Sep 12, 2014 5:55 am
Users browsing this forum: No registered users and 29 guests
