It is currently Wed Feb 26, 2020 11:39 am
PostPosted: Wed Apr 17, 2019 9:13 pm
Year and Trim: 2003 Bonneville SE
Hello-
My 2003 SE has a transmission cooler mounted! Need your help with the proper size of the lines in our 4t65e.
How did you guys bypass the radiator and connect it to the transmission? My problem is finding ANY fitting that will work, or even an adapter that will work with tye existing OEM quick connectors. I believe one is a 9/16"-18 and the other is a 3/8"-18. I did find a 3/8" fitting that may work, but that requires me draining the fluid simply to find out... hoping for your experience please!
Did anyone cut their metal lines and take that approach? If so, how did you make a buldge/notch/barb so that your house wouldn't simply fly off?
PostPosted: Wed Apr 17, 2019 11:48 pm
SO YOUR COOLER CAME WITH NO fittings?
you can cut the line into rad and splice in a metal line with a union: you need a flare tool to do it properly. but for the trans low pressure, you can use a compression fitting. you can then put the fitting of your choice on the end.
PostPosted: Thu Apr 18, 2019 5:21 am
Yeah- Hayden 679 cooler came with barbed fittings- they advertised an installation adapter for our trans, but that only works for one of the sides (as it turns out 8 qts later of fluid). Hoping to bypass the radiator/transmission heater altogether as I love in Florida.
PostPosted: Thu Apr 18, 2019 8:01 am
ok, I would first take the cooler to a home depot type place and find the correct size: if no joy, you go to a specialty plumbing place and you may get lucky
PostPosted: Thu Apr 18, 2019 8:13 am
if you get the flare tool, you can easily repair all metal lines including brake and home plumbing. if you in a hurry, you can cut the line into rad , flare, and use your existing kit.
There are no new unread posts for this topic. Cooler return line fitting on my 2004
GerGa
Sat Nov 14, 2015 2:45 pm
GerGa View the latest post
There are no new unread posts for this topic. Upper trans cooler line leaking at fitting
raa1144
Sun Jan 01, 2012 8:33 am
There are no new unread posts for this topic. External Transmission Filter
57chevythunder
Tue May 04, 2010 4:58 pm
There are no new unread posts for this topic. Transmission Experiences 4T65E - Especially Failure
1oldman
11
1745
Fri Feb 12, 2016 3:19 pm
There are no new unread posts for this topic. Any undesired effects with a transmission cooler?
GerGa
Mon Mar 27, 2017 10:42 am
