It is currently Thu Sep 25, 2025 1:42 pm
PostPosted: Sat Dec 31, 2011 11:29 pm
Year and Trim: 2001 Bonneville SLE
Hi all. I just replaced the radiator in my 2001 Bonnie and now the upper cooler line is pissing trans fluid at the fitting. It's a quick connect fitting with a spring clip in the fitting and a conical taper on the line with a yellow O ring looking thing behind the taper. I am wondering if there is supposed to be some kind of seal inside the radiator fitting that can fall out. It didn't start leaking until a day or two after I installed it. Anyone have any suggestions?
PostPosted: Sun Jan 01, 2012 8:33 am
Just had this happen on another member's 03 SLE... It ended up being a combination of the spring clip and the o-ring inside the fitting. The new radiator should have come with new fittings, I would be wiiling to bet that's your problem. :btruestory:
James May wrote:
Hello.
There are no new unread posts for this topic. Cooler return line fitting on my 2004
GerGa
Sat Nov 14, 2015 2:45 pm
GerGa View the latest post
There are no new unread posts for this topic. 03 SSEi Trans cooler line NOT 3/8 NPT
Mon May 23, 2011 9:26 am
Jrs3800 View the latest post
There are no new unread posts for this topic. Transmission external cooler fitting help at 4t65e Please
Kevdadi
Thu Apr 18, 2019 8:13 am
96 SSEi View the latest post
There are no new unread posts for this topic. Air line leaking
jedwards83
Mon Dec 19, 2011 11:50 pm
There are no new unread posts for this topic. Transmission cooler line connectors
GerGa
Mon Jan 15, 2018 8:23 am
maxi426 View the latest post
Users browsing this forum: No registered users and 18 guests
