It is currently Sat Oct 11, 2025 8:35 pm
PostPosted: Fri Oct 10, 2014 2:12 am
Year and Trim: 2000 Pontiac Bonneville SSEI L67
Hi ive been here a long time but never posted until now...Im stumped!! On my supercharger (2000 Bonnie) there is a port of some sort that is cracked.It is to the right side top of the supercharger looking into engine bay. the brake booster line comes up to meet it. the bypass solenoid line goes away from it. the other nub is capped. it has two bolts and out . There is apparently no name for this part on any diagram or anything on the net...i went to a junkyard and the dealer both today to find it..autozone sure doesnt know what it it(dealer either,chevy). this port is throwing a p0440 code small evap leak Ive been duck taping it up to try to save gas...its hurting my MPG alot. Like I said its cracked and leaking air I know if I could find what its called two bolts and out/in would get me right....thanks for your help! :)
Supercharged Supersonic
PostPosted: Fri Oct 10, 2014 9:54 am
I think you're talking about the vacuum tree on the blower.
PostPosted: Fri Oct 10, 2014 10:16 am
Agreed.
What is your current MPG? Most of us range around 22 - 24 average for an SSEi.
PostPosted: Fri Oct 10, 2014 3:49 pm
MPG right now is barely 20-21. I've seen as high as 28 out of this car, hwy. I got this car with 74 k last year acdelco plugs iridiums k&n etc...a ton of new parts really. I did finally find this part also scouring the net and forums...a eaton blower booster cap ...also known as intake manifold vacuum..is now on order from gmwholesale.com for approx. $8.50.this the last remaing part to tighten up this neighborhood wonder..my car is named for the supersonic concordr plane...ok thanks for the input!!
PostPosted: Fri Oct 10, 2014 5:59 pm
Depending on your driving, 20-21 isn't all too bad. I barely break 18 with straight Chicago traffic. Hahaha.
There are no new unread posts for this topic. Leaking brake booster
Oldman
11
3499
Sun Jan 06, 2013 9:27 pm
There are no new unread posts for this topic. Power Brake Booster
redbaron05
Sun Jun 05, 2011 11:07 am
02ssei View the latest post
There are no new unread posts for this topic. Replacing the brake booster
38bonne
Sun Jun 07, 2015 10:12 pm
38bonne View the latest post
There are no new unread posts for this topic. Security bypass question
00racer
Mon Apr 27, 2020 3:36 pm
00racer View the latest post
There are no new unread posts for this topic. Bypass or over ride of the O2 Sensor
Oldman
14
5244
Mon Sep 19, 2011 1:34 pm
Users browsing this forum: No registered users and 20 guests
