It is currently Thu Oct 02, 2025 2:44 pm
 Post subject: 4T60E HELP
PostPosted: Tue Apr 16, 2013 4:39 pm
Year and Trim: 98 Grand Am GT 2.4L Ld9 Twincam/ Quad 4 Stroked
97' 4T60E, it'll hang up in 1st all day til I let off the pedal causing it to shift into 2nd, than 3rd works fine, shifts into OD at about 45mph. Cruises 70 mph down the road in OD staying in gear and partial throttle will accelerate like should, soon as your into WOT it'll grab and bounce of the rev limiter, til I let off the gas to shift just like the 1-2 shift... I just changed the filter added fluid plus some Dura Lube... what would cause this symptom? Does not have no vacuum leaks what so ever, modulator is good.. anyone know of the symptom its experienceing? http://www.scribd.com/doc/34146615/4T60E Look at the 1st and 2nd gear in Overdrive, plus 3rd, and 4th if you will... Also the 3-2 shift down in Overdrive for WOT acceleration-(this uses the B solenoid) and the 4-3 shift down, which my transmission works fine for this and is using solenoid A for this one ... I'm definetly thinking maybe a 1-2 shift valve sticking, Especially since the factory ones are aluminum and could perhaps have some metal or gunk in it... I mean what else will cause the 3-2 kickdown to hit the rev limiter if I dont let off the gas to help shift? plus the 1-2 shift?... i'm pretty sure the bands and clutches are good in this transmission, it really feels like it. Any transmission guys out here?
 Post subject: Re: 4T60E HELP
PostPosted: Wed Apr 17, 2013 8:49 am
Year and Trim: '99 Montana
'92 Trofeo
Just to clarify, 1-2 and 3-4 will not upshift at WOT? But all kick-downs work without any delay?
PostPosted: Wed Apr 17, 2013 7:44 pm
Did you go with a different gear ratio?
There are no new unread posts for this topic. Can I use a 96' 4t60e in place of a '95 4t60e PLEASE HELP
kcirrab
Thu Jul 11, 2019 4:00 am
1996 Oldsmobile View the latest post
There are no new unread posts for this topic. 4T60E Buzzing
PLAGUE PHANTOM
Sat Oct 20, 2012 6:27 am
PLAGUE PHANTOM View the latest post
There are no new unread posts for this topic. SK 4T65e kit in 4T60e
enslow
Thu Aug 19, 2010 12:49 am
enslow View the latest post
There are no new unread posts for this topic. 95 4T60E Failure
3896
Thu Sep 01, 2016 7:04 pm
Jrs3800 View the latest post
There are no new unread posts for this topic. 4T60E interchangeability
[ Go to pageGo to page: 1, 2, 3, 4, 5 ]
spoiledred94
90
16726
Thu Apr 30, 2009 12:49 pm
