It is currently Thu Oct 02, 2025 2:45 pm
 Post subject: 4T60E Buzzing
PostPosted: Fri Oct 19, 2012 10:19 pm
Just recently my transmission has been making a buzzing sound. The fluid was changed 5 years ago. The fluid is a orange color and does not smell burnt. No metal particles on dipstick. Transmission drives fine except for this noise. Will a filter and fluid flush fix this sound? I was told it was the chain in the transmission making noise. It comes from the driver front side. Wheel bearing ls were changed last year with Timken brand.
 Post subject: Re: 4T60E Buzzing
PostPosted: Fri Oct 19, 2012 10:22 pm
Could also be a sticky valve or check ball in the valve body. Could try adding some LUcas or seafoan trans tune before doing the filter and fluid.
PostPosted: Sat Oct 20, 2012 3:03 am
How much would I add and how many miles should I keep it it the trans until the fluid filter swap?
PostPosted: Sat Oct 20, 2012 3:25 am
Depends on what you get. Follow the directions and run it a 100 miles or so before doing the filter.
PostPosted: Sat Oct 20, 2012 5:49 am
Ok...ill try that
PostPosted: Sat Oct 20, 2012 6:27 am
Also forgot to mention that the sound only occurs when the transmission is at operating temp. The sound is nonexistent if the transmission is cold.
There are no new unread posts for this topic. Can I use a 96' 4t60e in place of a '95 4t60e PLEASE HELP
kcirrab
Thu Jul 11, 2019 4:00 am
1996 Oldsmobile View the latest post
There are no new unread posts for this topic. 4T60E HELP
98GrandAmLD9
Wed Apr 17, 2013 7:44 pm
Jrs3800 View the latest post
There are no new unread posts for this topic. 95 4T60E Failure
3896
Thu Sep 01, 2016 7:04 pm
There are no new unread posts for this topic. SK 4T65e kit in 4T60e
enslow
Thu Aug 19, 2010 12:49 am
enslow View the latest post
There are no new unread posts for this topic. 4T60e question(s)
rynmcdonald
Sat Nov 26, 2022 6:59 am
rynmcdonald View the latest post
