It is currently Sat Oct 11, 2025 11:51 pm
 Post subject: Install STB
PostPosted: Wed Jan 18, 2012 1:45 pm
Just curious on how to do it, do you take out all three of the bolts then use longer bolts to bolt it down. I was just thinking about
doing it but thought it was unsafe to remove all the bolts at once. It seems very simple to do and i just want to make sure i am not
under thinking it and mess something up.
 Post subject: Re: Install STB
PostPosted: Wed Jan 18, 2012 1:48 pm
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Whats an STB?
PostPosted: Wed Jan 18, 2012 2:02 pm
Moderator
Moderator
Year and Trim: 09 G8 GT
Strut Tower Bar.
PostPosted: Wed Jan 18, 2012 2:07 pm
Strut tower brace.
There is no problem removing all the strut bolts, the cars weight forces them into the pockets.
PostPosted: Wed Jan 18, 2012 2:27 pm
I wouldn't lift or drop the car or mess with the steeringwheel while you have the nuts or bolts off. That'll goof your alignment up.
PostPosted: Wed Jan 18, 2012 4:36 pm
Ok thank you, does the STB have to be modified in anyway. I heard that the 3.8 alternator gets in the way, is that true?
PostPosted: Wed Jan 18, 2012 4:55 pm
I've read where some have had a clearance issues with the alternator on the L67, but I have about 3/4" clearance. I'm not sure but I think the alternator is maybe in a different position on the L36, so you might not have any problem at all. If your trans mounts are worn the engine might be able to hit it, but if it moves that far the mounts should have been replaced already. Also longer bolts are not necessary.
PostPosted: Fri Jan 20, 2012 8:25 am
I had a clearance problem when I put my stb on. I had to bend the brackets to make some more room.
Intense FWI - Home Brewed Tune - 3in Cat'ed DP Res Delete - 3.6 Pulley - Solid Front Mount - STB
PostPosted: Wed Apr 25, 2012 11:24 pm
Year and Trim: '05 SLE
Eric and I will be adding these to our '05 SLEs shortly. If I could easily located longer bolts (did not come with braces) I would prefer to use these. Anyone know where I might be able to get these?
WhiteArrow3800 - sounds like oyu used the factory bolts. No issues to date? How long has it been installed?
Scott
'05 SLE, Crimson Tintcoat, 89K
Mechanical: FWI, FelPro LIM and Valve Cover Gaskets, Ported LIM, Prestone Green Coolant, 180 Thermostat
Exterior: Tinted - 35% Front, 20% Rear
Interior: GXP Carbon Fiber Upgrade, Tinted Reflectors
PostPosted: Wed Apr 25, 2012 11:28 pm
I just went to Lowes and got em, took one of the factory ones with for size.
James May wrote:
Hello.
PostPosted: Wed Apr 25, 2012 11:42 pm
How much longer did you go with over the factory - like 1/4"?
Scott
PostPosted: Thu Apr 26, 2012 6:58 am
I think so, that's about the thickness of the bracket.
James May wrote:
Hello.
PostPosted: Thu Apr 26, 2012 12:02 pm
I did re-use the stock bolts without issue for 3 years now.
Last edited by WhiteArrow3800 on Thu Apr 26, 2012 12:04 pm, edited 1 time in total.
PostPosted: Thu May 03, 2012 12:43 am
Thanks guys! Got them both installed on our cars the last few days.
Scott
There are no new unread posts for this topic. help on fwi install
fromtheashes
26
2823
Mon Jun 23, 2014 11:17 pm
fromtheashes View the latest post
There are no new unread posts for this topic. nit able to install a fwi
1999_pontiac_ssei
Sun Aug 22, 2010 9:31 am
willwren View the latest post
There are no new unread posts for this topic. Got the LIM! what else do I need to install it?
alexcoqui
Sat Jun 07, 2008 7:52 pm
alexcoqui View the latest post
There are no new unread posts for this topic. Gen V install?
redzmonte
20
3241
Thu Mar 28, 2013 9:47 pm
There are no new unread posts for this topic. Not in any hurry to install this, but...
sandrock
Wed Mar 17, 2010 8:42 pm
