It is currently Wed Oct 08, 2025 6:48 am
PostPosted: Sat Aug 31, 2013 3:57 am
Year and Trim: 2000 B-ville (stock)
Well, went to work, arrived and the drivers door controls wouldn't let any windows down, nor lock the doors or reset the memory seating. Also the windshield wipers wouldn't work.... I checked all fuses.... none blown. I did remove the relay for the windshield wipers, then it worked and now the passenger door window button won't let the passenger window down...
Can this be related to the ground underneath the drivers seat?
PostPosted: Sat Aug 31, 2013 10:48 am
Normally when the drivers door functions stop working like that it is a bad window switch module. Not sure for your wipers though, have you ever had any other odd happenings with them?
PostPosted: Sat Aug 31, 2013 11:22 am
Nope, no ptoblems at all. I did switch a few relays out. I think that number 30 under the hood is bad. I switched it out with another. It didnt work as well the orignal one. I am hitting the salvage yards today. When it first happened, passenger window still worked on its own. Now that window will not operate at all.
PostPosted: Tue Oct 15, 2013 4:46 pm
I checked the ground on both lower pillars. No corrosion was found. Is there another location for grounds? My windshield wiper works correctly sometimes, then other times it takes 10 mins for them to work. All fuses are good. My passenger door lock stopped working, but now it works.
Any help would be appreciated
PostPosted: Tue Oct 15, 2013 4:54 pm
PostPosted: Tue Oct 15, 2013 4:56 pm
The rear windows are not affected. Driver and passengers window doesnt work, but the power door lock on the passengers side does wk
PostPosted: Tue Oct 15, 2013 5:00 pm
Is there anyone that has the drivers control module for sale? If so, please give me a call 808-542-2496 Ezell I am in Hawaii
PostPosted: Tue Oct 15, 2013 11:52 pm
2004 Bonneville GXP
PM harofreak00. He always has a bunch of them. Water getsd into the wiper motor control board and can cause problems with the wipers. See the list of common problems posted under . . http://www.pontiacbonnevilleclub.com/forum/2000-2005-other-than-gxp/topic25362.html. Haro can also sell you the parts you need to fix this.
bobgto65
PostPosted: Wed Oct 16, 2013 1:38 am
I will check the ground under the seat..... I think that may be the issue
PostPosted: Wed Oct 16, 2013 5:41 am
Never hurts to check something that is free.
PostPosted: Thu Oct 17, 2013 1:43 am
Well, checked the ground.....no corrosion at all. The connector was clean. I tested the power leads to the module. There were two leads with power , a large orange wire and a small one and one blue w/white stripe. All were it appears the module is shot
There are no new unread posts for this topic. 2000 Bonneville SE Window / Lock / Mirror Controls
viksfan22
Thu Jun 23, 2022 9:06 am
dougtoth View the latest post
There are no new unread posts for this topic. Driver window controls and driver A/C
forevercasual
Mon Jul 23, 2012 5:43 pm
There are no new unread posts for this topic. driver door controls don't work????
gxp937
Mon Mar 23, 2009 2:04 pm
There are no new unread posts for this topic. All driver's door electronics work EXCEPT driver's window
bradleymc
Fri May 31, 2019 12:50 pm
Bglenn26 View the latest post
There are no new unread posts for this topic. 2005 GXP driver door controls are dead
Koto
Mon Jun 18, 2012 12:57 pm
Koto View the latest post
