It is currently Wed Oct 08, 2025 6:53 am
PostPosted: Tue Jun 08, 2010 9:44 pm
Year and Trim: 2000 SSEI champagne
Stock
The oil pressure gauge works has 45 Lbs of oil pressure running, have checked it with external gauge no problem.
Will work fine then drop to 0 and come back on. Anyone got a schematic or advice.
PostPosted: Tue Jun 08, 2010 10:26 pm
Have you checked oil level? Usually it will do that when its running low and you are braking.
PostPosted: Wed Jun 09, 2010 10:15 am
When you checked it with a mechanical gauge, was it under the same conditions? Does the gauge always do a full sweep during start up? Even though they usually fail to the high reading, the oil pressure sensor is the most likely suspect if you answered yes to those and Haro's questions.
PostPosted: Wed Jun 09, 2010 11:52 pm
Stock
the gauge goes to 120 then back to 45 or 50 I think it is a ground problem when you put it in drive with foot on the brake it is fine. You put it in reverse with foot on brake and it drops to 0. have moved wires and makes no difference.
PostPosted: Wed Jun 09, 2010 11:58 pm
Put in a new sender, its bad. $40 from any parts store.
PostPosted: Thu Jun 10, 2010 12:08 am
Stock
This started one year ago it was staying on 120 that was no problem then it started dropping to 0 so I replaced it.
Then it stayed on 0 all the time now it is doing the jumping around. Still think it is the sender if so which brand.
PostPosted: Thu Jun 10, 2010 12:43 am
I recently replaced two oil pressure senders, one in my 2000 SSEi, and another in a 2003 SSEi that I sold. I got both senders from Advance, and they both worked great. If the sender stayed on 0 from the time you installed it, you should have taken it back right away.
PostPosted: Thu Jun 10, 2010 12:48 am
AC/Delco is recommended. There have been reports of other brands failing after a year or two.
There are no new unread posts for this topic. Oil Pressure Gauge 120 PSI
Noah.Dreams
Tue Nov 04, 2008 9:48 am
BillBoost37 View the latest post
There are no new unread posts for this topic. oil pressure gauge
THEEMANG
Fri Jan 20, 2012 9:49 pm
THEEMANG View the latest post
92BonnevilleSE
Thu Dec 17, 2009 2:12 pm
92BonnevilleSE View the latest post
There are no new unread posts for this topic. 1994 SSEi gauge problems
Hoganct
23
8215
Sat Oct 22, 2011 7:17 pm
Hoganct View the latest post
There are no new unread posts for this topic. 92 SSEi Cooling Fan & Gauge Cluster issues.
Dopey85
Wed Jun 09, 2010 9:32 am
J Wikoff View the latest post
