It is currently Wed Oct 08, 2025 6:48 am
PostPosted: Sat Jun 07, 2008 9:15 pm
Year and Trim: 1994 Buick Park AVenue
i was driving down the road as i was coming to a red light every dash light came on i pulled over and and they went off, so i pulled a u turn. the alt gauge started flickering i checked the wiring going to the battery and the alt.. is there anything esle i can check
Thanks
PostPosted: Sun Jun 08, 2008 10:46 am
Check for corrosion UNDER (inside) the boots on the battery cable ends. You must remove the boots to find it. Also check the ground Bus on each side of the car, under the carpet just inside the door sills on each front door for corrosion. These are the two most common culprits for your classic symptoms.
PostPosted: Sun Jun 22, 2008 2:36 am
thanks man, i checked the battery cables... in between them was nasty so i took a wire brush to them and that took care of the problem i was having..
There are no new unread posts for this topic. Security light and car trying to die while driving.
Weekender01
Mon Sep 07, 2015 5:12 pm
cjski View the latest post
There are no new unread posts for this topic. Instrument cluster light come on while driving.
samples08
Tue Sep 29, 2015 10:19 pm
There are no new unread posts for this topic. 04 SLE Dash Light Fuse Location? (solved)
ddrtears
Thu Apr 08, 2021 2:30 pm
ddrtears View the latest post
There are no new unread posts for this topic. 1995 Bonneville Traction Control Light on Dash
Tech3D
Sat Oct 29, 2011 9:16 am
human View the latest post
There are no new unread posts for this topic. Tail Light/Brake Light/Turn signal light question
1oldman
Fri Sep 23, 2016 9:21 pm
