It is currently Tue Aug 11, 2020 8:20 pm
PostPosted: Fri Sep 16, 2016 8:36 pm
As I remember on the 2005 SE Bonneville, there are two tail lamps on each side, one brake lamp on each side, and two turn lamps on each side. If I'm correct, the tail lamp/turn lamp is a single filament bulb, the tail lamp/brake lamp/turn lamp is a dual filament bulb. I'm wanting to change the socket and wiring on the outside tail lamp/turn lamp bulb. I'm tired of burning through brake lamps. The '92 had dual brake lamps on each side and the bulbs lasted a lot longer. and I'm in no hurry to spend a ton of money (in my opinion) converting to LED as at the moment I need to put the funds to use somewhere else.
your comments and thoughts are solicited and welcome. Thank you - BC
PostPosted: Fri Sep 16, 2016 9:54 pm
The turn signal is a lamp (single filament) on its own on the top, outer portion of the housing beside each respective reverse lamp. It is completely independent of the tail/brake lamp bulbs in location and operation. There are two tail/brake lamp (dual filament) bulbs on the lower portion of the housing that operate together. There is also a 194 marker lamp on the lower, outside of each lamp assembly. In my opinion, you need to purchase a decent quality "Long Life" bulb. Not all bulbs have the long-life designation.
PostPosted: Fri Sep 23, 2016 9:21 pm
thank you for the post. I remembered as soon as I read your post. We've been having some really long days and am tired and not thinking too good. I replaced the bulbs with dual intensity red LEDs. thank you again. - BC
There are no new unread posts for this topic. Problem with Left Blinker-Turn Signal Light
laimisl
12
4808
Mon Oct 06, 2008 9:09 am
bad.moshi View the latest post
There are no new unread posts for this topic. Tail Light
deano55
Sat Mar 17, 2018 1:09 pm
deano55 View the latest post
There are no new unread posts for this topic. Fog Light Turn Signals
KelvinVV
Thu Oct 10, 2013 6:50 pm
samples08 View the latest post
There are no new unread posts for this topic. Center tail light up
xrob
Wed Jun 06, 2012 11:48 am
Archon View the latest post
There are no new unread posts for this topic. tail light socket
windshield_time
Thu Jan 15, 2009 11:24 pm
