It is currently Thu Sep 25, 2025 1:38 pm
PostPosted: Mon Mar 31, 2014 3:34 pm
How in the world do you remove those two lines from the under side of the trans? is it some kind of weird disconnect? or do the nuts actually turn and come off like normal?
PostPosted: Mon Mar 31, 2014 4:50 pm
Carefully pull the plastic stop ring back. There is a thin C-clip holding the line in, use a pocket screwdriver to pry it up. The line then just pulls straight out.
At least, that's the return line (pointing toward the rear of the trans). I didn't need to mess with the output line.
PostPosted: Mon Mar 31, 2014 5:35 pm
Ah yeah everything is so so dirty.
BUT when i went looking around for a socket for the drive nuts I did pick this kit up at HF
I haven't opened it yet. but I'll look/try what you did. Thanks!
PostPosted: Mon Mar 31, 2014 7:55 pm
oh god.... im so dumb
all this time i was thinking it was a tiny tiny tiny ring BETWEEN the line and that nut... i took a freakin picture to show to a coworker. i zoomed way in on the picture a between the rust and dirt i see a shiny clip.
There are no new unread posts for this topic. Transmission Oil Cooler Lines and a major shake!
happygoluckynic
Wed May 05, 2010 11:27 am
Archon View the latest post
There are no new unread posts for this topic. Gotta replace Transmission cooler lines is it easy?
03SSEISUPERCHARGED
Fri Dec 08, 2017 8:46 am
03SSEISUPERCHARGED View the latest post
There are no new unread posts for this topic. What are the pressures inside trans cooler lines?
imidazol97
Thu Sep 20, 2012 8:23 pm
RJolly87 View the latest post
There are no new unread posts for this topic. Removing tranny lines from Radiator on 2000 Lesabre HELP !!!
cvcman
Sun Sep 06, 2015 9:13 pm
98SSE View the latest post
There are no new unread posts for this topic. Any undesired effects with a transmission cooler?
GerGa
Mon Mar 27, 2017 10:42 am
Users browsing this forum: No registered users and 27 guests
