It is currently Thu Sep 25, 2025 11:54 am
PostPosted: Thu Sep 20, 2012 5:59 pm
What level of pressure in the trans cooler lines running to the radiator? Higher than the max #15 in the radiator coolant? Or will the coolant get into the transmission oil?
PostPosted: Thu Sep 20, 2012 7:40 pm
It's higher than 15 PSI, but not like 500 PSI internal line pressures, either. I'd venture a guess at 20 PSI.
It will get in the coolant first, I'd think.
PostPosted: Thu Sep 20, 2012 8:23 pm
It will go both ways, because when the pump is not running, the system is at 0, which is less than the 16psi that remains in the radiator.
There are no new unread posts for this topic. Removing transmission's oil cooler lines.... help!
mrrcom
Mon Mar 31, 2014 7:55 pm
mrrcom View the latest post
There are no new unread posts for this topic. Transmission Oil Cooler Lines and a major shake!
happygoluckynic
Wed May 05, 2010 11:27 am
Archon View the latest post
There are no new unread posts for this topic. Gotta replace Transmission cooler lines is it easy?
03SSEISUPERCHARGED
Fri Dec 08, 2017 8:46 am
03SSEISUPERCHARGED View the latest post
There are no new unread posts for this topic. diy trans cooler flush?
bonneville dan-o
Thu Mar 25, 2010 4:16 pm
bonneville dan-o View the latest post
There are no new unread posts for this topic. Trans Cooler Questions
yonkerse
Sat Apr 02, 2011 7:04 pm
Users browsing this forum: No registered users and 15 guests
