It is currently Sat Oct 11, 2025 8:47 pm
Post new topic Reply to topic  [ 67 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Tue Jun 16, 2009 7:22 pm
Year and Trim: 2012 Nissan Sentra SR Special Edition
my mechanic has already said that he will be removing the PLog to get to the bolt, then reattach it.
seeing that it is the front and not the rear, I imagine it would be easier to get to.
Jovan
PostPosted: Tue Jun 16, 2009 7:55 pm
Yeah he should be ok. It's a good thing it didn't break way inside the block...
New rule, don't let Matt near the rusty bolts that may snap :wink:
I must say, Jovan, you've got one of my favorite 2000's, it all looks great... even if it may be kinda slow :P Those 12.111's are just around the corner though!
PostPosted: Tue Jun 16, 2009 7:59 pm
Year and Trim: 2001 GMC Yukon XL
not my fault that im stronger than metal :btruestory:
-Matt
PostPosted: Tue Jun 16, 2009 8:44 pm
"Oh what a deadly web we weave when we go to Ed's place for MWBF". :twisted:
Jovan
PostPosted: Tue Jun 16, 2009 9:03 pm
Year and Trim: 2009 G8 GT
Mac077 wrote:
Kyle...how difficult was that to do? It looks really, really nice and I would love to do something like that to mine.
It was easy and I'm surprised how many people like it. I did it just to hide water build up. :wink:
I put an Intense sticker down, couple layers of VHT nightshades, let it dry, peeled off the sticker, put a few more coats over the whole thing, and ta da!
2009 G8 GT - White Hot
FMS Custom Cam, Yank 3600 SS, 1LE (ZL1) 3.91, SLP Longtubes, Magnaflow cat-back, Rotofab CAI, tuned via HPTuners
415/391
PostPosted: Tue Jun 16, 2009 9:12 pm
Deadly, your car almost didn't make it! I was wondering what the hell we might have effed up when it was all put back together....
Stupid strut tower brace... :evil:
When we re-installed ED's STB it got put in upside down. For some reason the Alternator was hitting it installed that way, but not flipped around the way it was before. There was 1/2" difference atleast. When it was hitting, it was causing KR all thoughout gear, terrible noises, etc.
PostPosted: Tue Jun 16, 2009 9:26 pm
humor me........................
if I did have an exhaust leak, it would just be up at the PLog correct? The rear PEM showed no signs of this?
Jovan
PostPosted: Tue Jun 16, 2009 11:14 pm
An exhaust leak could have been anywhere, but I remember Ed re-torqued the manifold bolts after the whole freak out.
When I went out to scan your car it was knocking all the time, which is what Jason is probably talking about.
On a stock 00+ SSEi BIN your knock sensors start listening for knock over 50kPa, so I only had to give a little bit of throttle to see 7+* of KR. It was very ugly.
415/391
PostPosted: Wed Jun 17, 2009 12:49 am
Yup, we could feel it in the cabin, and it was audibly different because of the contact and KR. It was really bad, we went 1/4 mile, turned around and idled back it sounded so bad. :eek2:
PostPosted: Fri Jun 19, 2009 7:52 pm
well just got back from the mechanic and have been informed that the bolt has bottomed out and will not be able to come out. He said he was at first excited because he could actually see part of the bolt sticking out, but ended up using all available means to no avail, so I have been told to be on the lookout for certain sounds at or around 12,000 miles to signal that the gasket is starting to fail. From my buddy perspective, I have been told I basically have two options:
JB Weld the PLog to the head to seal the area, or.....
find a replacement set of heads to put on the car.
Otherwise the O2 sensor and MAF screen have been changed, the shocks will be done next Saturday.
soooo........................... that's the scoop
Jovan
PostPosted: Fri Jun 19, 2009 9:38 pm
addendum...........
Since my mechanic installed a new bolt to attach the oil dipstick housing, I was not able to take pics of what the broken bolt looked like aftermath. These were the only ones I could get.
Jovan
PostPosted: Fri Jun 19, 2009 10:07 pm
I am seriously at a loss.. How did he manage to get a bolt part way into the head if a bolt was sticking out... Did he drill the bolt? and tap? Did he try to use an easy out?
I am not really up for the fun of removing a Head/s but I would help you if I was there..
Maybe I'm grumpy, But I would have loved to have had a look at that bolt
PostPosted: Fri Jun 19, 2009 10:18 pm
I must admit that if there was a bolt sticking out, I would have welded something to it to try to get it out. That's how I got my sparkplug out of my head that I broke two years ago.
PostPosted: Fri Jun 19, 2009 10:51 pm
I'm guessing he drilled into the bolt and tapped it and bolted it on.
PostPosted: Fri Jun 19, 2009 10:55 pm
IIRC, that's what he said he did. (memory is a little foggy).
Jovan
PostPosted: Fri Jun 19, 2009 11:35 pm
I think it can be removed by some means. If he tapped a bolt into it then he should have the proper tools to remove that stud.
415/391
PostPosted: Fri Jun 19, 2009 11:41 pm
:dontknow:
Jovan
PostPosted: Fri Jun 19, 2009 11:48 pm
Bluntly, go to another mechanic.
415/391
PostPosted: Sat Jun 20, 2009 1:09 am
jovan, like i tried to tell you, the bolt can stay if it must....just drill through it a little small than the bolt, then tap it and put new bolt in
batta boom- batta bing
PostPosted: Sat Jun 20, 2009 11:03 pm
Year and Trim: 2003 Black bonneville SE
looks like a great time!
    120,xxx miles,180° thermostat, cold air intake with k&n filter and heat shield, CB radio (it's necessary),
      cleared headlights and tail lights, new tires, Sylvania Silverstar* 9005 High Performance high-beams,
      Sony X-Plodes, Scangauge 2
There are no new unread posts for this topic. Took a few pics and vids of the 99 SSEi today...
dangrus4060
Fri Apr 30, 2010 1:24 am
dangrus4060 View the latest post
There are no new unread posts for this topic. Some vids.
2257
Mon Feb 06, 2012 12:16 am
There are no new unread posts for this topic. weeeeee ;) (2 vids)
repinS
Mon Dec 21, 2009 3:09 am
BonneMe View the latest post
There are no new unread posts for this topic. My first ( of many ) Vids, On my road to 13 seconds .....
comatoast
29
2585
Mon Oct 11, 2010 9:55 pm
comatoast View the latest post
There are no new unread posts for this topic. 0-58ish vid of my 01' SE. !!UPDATED with more VIDS!!
RJGill84
Tue Nov 04, 2008 1:37 am
RJGill84 View the latest post
