It is currently Tue Sep 30, 2025 9:14 pm
Post new topic Reply to topic  [ 6 posts ]
PostPosted: Fri Dec 01, 2017 2:50 pm
Year and Trim: 95 Pontiac Bonneville
HELP!!!! I am gonna cry!!! we bought a 95 Bonneville & the transmission went in it within a month! never even put the plates on it!! So we bought a damaged 94 Bonneville, that we took the transmission out of & its at the shop right now... we just noticed that the key tag says 92 and double checked the door, yep it's a 92!! I'm afraid this guy totally screwed us!! Can anyone tell me if a 92 is compatible with a 95???
thanks
PostPosted: Fri Dec 01, 2017 3:44 pm
Year and Trim: 1992 SSE
Supercharged or naturally aspirated?
PostPosted: Sat Dec 02, 2017 1:14 am
yes, I believe it will be if the trim matches, the supercharged engines need a different one than the lower models. the tranny place would have told you already if it wont work.
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
PostPosted: Sat Dec 02, 2017 10:22 pm
...might be tricky, the 95 model year was a one year only for a lot of things with OBD1.5 in the mix. I know that you have to put a 95 transmission in a 95 Chevy Astro.
https://photos.google.com/album/AF1QipOYkkevV0gKTHc_8Cstuy8yS1Qyx6SiIKeTzuHy
PostPosted: Mon Dec 04, 2017 12:15 pm
Year and Trim: '99 Montana
'04 Dirtymax
'97 Camaro
'92 Trofeo
http://www.gmtuners.com/tech/440_4T60E_4T65E.htm
I don't believe you can just drop a '92 trans into a '95. It will mount in and bolt down fine, but there were slight differences in the controls internally. I think the main difference would be the torque converter apply strategy (extra solenoid on the 95) which is not compatible. I don't know if the harness is different. It might bolt in and plug in fine, but you would have issues and a check engine light for the TCC, and reduced gas mileage.
Boost addict
The Fleet:
'97 Camaro - Top swap
'05 STS - V8, AWD, her DD
'92 Trofeo - Fair weather DD
'99 Montana - top swap 3800
Current project:
Something cool, trust me.
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
Gone to greener pastures:
'97 LeSabre - Top swap
RIP:
'86 LeSabre - pictures
'93 SE - L67
PostPosted: Sat Dec 09, 2017 12:59 pm
Both the 92 and 95 Bonneville 4T60E use the PWM strategy... But they are wired differently internally... I really wouldn't go backwards from 94- 95 to 92, but I would go forward like 96 and or 97 as the 4T60E was improved for those years.. the 94-97 4T60E for the H body is wired the same.. 92-93 is wired differently..
There are no new unread posts for this topic. transmission on its way out?? o.O
douellette88
Sat Jul 16, 2011 9:18 pm
sonoma_zr2 View the latest post
There are no new unread posts for this topic. Transmission
PLAGUE PHANTOM
32
5518
Thu Mar 08, 2012 5:48 am
PLAGUE PHANTOM View the latest post
There are no new unread posts for this topic. transmission help
78elcaminoman
14
5824
Wed Jun 03, 2009 8:02 pm
78elcaminoman View the latest post
There are no new unread posts for this topic. I think my transmission is gone
LeSabreUltra
14
2049
Wed Mar 03, 2010 5:45 pm
Jrs3800 View the latest post
There are no new unread posts for this topic. Transmission Lag?!?
94SilverSSEi
16
1845
Sat Feb 20, 2010 3:44 pm
Users browsing this forum: No registered users and 11 guests
