It is currently Sat Oct 11, 2025 8:29 pm
 Post subject: 180 thermostat
PostPosted: Sat Jun 11, 2011 11:22 pm
I wanted to get the 180 degree thermostat, i currently have just a FWI. i will be getting the zzp 2.5 downpipe and HF cat. My question is
can i get the thermostat without getting a tune?
 Post subject: Re: 180 thermostat
PostPosted: Sat Jun 11, 2011 11:26 pm
This has been discussed numerous times, but yes. However, the only time you'll actually be at 180* will be on the highway, even in the winter. Any town driving will bump that back up to the OE programmed fan turn on temps, somewhere around 200*.
PostPosted: Sun Jun 12, 2011 9:37 am
There is another benefit to the L36. Removing some of the heat from the UIM, particularly if you haven't replaced it yet (in which case you're going to have a catastrophic failure). EGR burn-through is a guarantee, and if it happens, odds are high you'll kill the bottom end of your motor.
PostPosted: Sun Jun 12, 2011 10:32 am
I did replace the upper, around 4 months ago.
PostPosted: Sun Jun 12, 2011 10:38 am
Would this be a suitable thermostat
http://www.rockauto.com/catalog/moreinfo.php?pk=49240
or should i get the one from intense? thanks
PostPosted: Sun Jun 12, 2011 10:53 am
Yup. That's a good one. I suggest drilling a 1/16" diameter hole in the rim, just inside of where the rubber seal rides. It helps burp air out of the system.
There are no new unread posts for this topic. 180 thermostat
xyeLz
18
1723
Tue Mar 04, 2014 2:03 pm
xyeLz View the latest post
There are no new unread posts for this topic. 180 vs 160 thermostat
xyeLz
Mon Mar 03, 2014 12:31 am
There are no new unread posts for this topic. Thermostat questions..
Sirhc
19
3768
Wed Dec 01, 2010 10:16 pm
Sadden View the latest post
There are no new unread posts for this topic. 180 Thermostat question
AJT2004
Mon Oct 25, 2010 4:59 pm
atom View the latest post
There are no new unread posts for this topic. 180 degree thermostat question
SSEIking
12
2931
Thu May 17, 2012 10:25 pm
