It is currently Sun Oct 12, 2025 12:00 am
 Post subject: 180 Thermostat question
PostPosted: Sun Oct 24, 2010 8:01 pm
Has anyone had any problems with using a 180 thermostat because the factory one is 195 degrees? and does it really help with performance?
PostPosted: Sun Oct 24, 2010 8:04 pm
No, and no.
It's a safety feature primarily for helping to prevent breakdown of the non-supercharged upper intake (or delay the inevitable unless you take a proactive preventive approach).
It does very little unless you take manual control of your radiator fans or PCM programming.
It will not cause any adverse effects with regards to mileage, and it's not worth 1 or 2 horsepower at the most.
PostPosted: Sun Oct 24, 2010 8:34 pm
Year and Trim: Pontiac Bonevvelle SSEi 3.8 1993 y.
that is needed that to program ventilators under a thermostat 180
PostPosted: Sun Oct 24, 2010 9:11 pm
Atom, are you asking what needs to be programmed? We need to know what year of car you have first.
Nothing HAS to be programmed, but it should.
PostPosted: Sun Oct 24, 2010 9:13 pm
Year and Trim: 1999 SSEi
1997 SSEi-Resting-353K
the pcm should be programmed to account for the cooler temps. otherwise the system may fluctuate between closed and open loop, thinking the car hasn't warmed up yet.
PostPosted: Sun Oct 24, 2010 9:14 pm
Travis, that's not a big concern at all with a 180. When you go to 160, it is. What needs to be programmed to take advantage of the 180 is the fan turn-on temp.
PostPosted: Sun Oct 24, 2010 9:24 pm
Year and Trim: 2004 Volvo S60
Being a user of the Intense T-stat, yes, fans need to be reprogrammed with new low/high on temps, the 180 doesn't make a big change, my car does see lower temps most of the time, but after sitting in slower traffic for a bit it becomes very apparent that I should some day adjust my fan temps...
Make note the Intense one has a larger opening which they say keeps the flow better which results in lower temps (meaning closer to 180 more often)
PostPosted: Mon Oct 25, 2010 5:02 am
My the auto 1993 year. So however, is it necessary that to program and as it to do?
PostPosted: Mon Oct 25, 2010 8:06 am
How hot are your summers in the Ukraine? 90°F? It would help a little without programming, and you can do a manual radiator fan switch/override.
PostPosted: Mon Oct 25, 2010 4:59 pm
there was 90F. This summer there was 110F-115f three months. this was amargedon. after a 105f car begins to overheat, especially in a city traffic
There are no new unread posts for this topic. 180 degree thermostat question
SSEIking
12
2932
Thu May 17, 2012 10:25 pm
There are no new unread posts for this topic. 180 thermostat
AJT2004
Sun Jun 12, 2011 10:53 am
willwren View the latest post
There are no new unread posts for this topic. 180 vs 160 thermostat
xyeLz
Mon Mar 03, 2014 12:31 am
xyeLz
18
1723
Tue Mar 04, 2014 2:03 pm
xyeLz View the latest post
There are no new unread posts for this topic. Thermostat questions..
Sirhc
19
3769
Wed Dec 01, 2010 10:16 pm
Sadden View the latest post
