Cigar lighter question
Solid_speed
- Year and Trim: 2002 ssei
Do these cars not have a cigar lighter that supplies current to things plugged into it even with the car off? I can't charge my phone in the car for more than 5 min with the car turned off with the ignition off. If not, is there a way to make it so that it's always on?
- harofreak00
Re: Cigar lighter question
Both cigarette lighters have switchable fuses in the underhood fusebox. Depending on how the fuse is installed, it can either be ACC or ALL-time power.
- Attachments
[The extension jpg has been deactivated and can no longer be displayed.]
ddalder
OMG! Where did that come from??? LOL
Oldman
- Posts like an LN3
- Year and Trim: 2001 SSEi
I thought that was pretty cool when I found it out too. If you don't have an owners manual, you should try to find one. I have seen a few in glove boxes at salvage yards. Setting different driver settings, and all the options on the DIC are pretty impressive. There's a lot of "tricks" to these cars like this one with the fuse location for the cigar lighters that I would not have known without that owners manual.
Pretty cool cars!
Pretty cool cars!
ddalder
I was joking with Andrew because that's the custom decal he made for my car. If you look really close, you'll see the heated washer system fuse which of course only one Bonneville has in that fuse bloxk
