Need new brakes, what brand?
xyeLz
Year and Trim: 2001 SSEi
Post by xyeLz »
Cars at that point where I gotta get new rotors and brakes. I'm thinking of swapping out for some better performing aftermarket brakes. I think Brembo might be too expensive (correct me if I'm wrong - I haven't looked yet) but I would like something priced well that performs well for our cars. Obviously these ain't no Ferrari's ;). My only other requirement is that they come painted red from the factory. Is Brembo a brand anyone here has tried?
Black 2001 SSEi | Performance: INTENSE FWI, INTENSE Shift Kit, INTENSE 180* Thermostat, GXP Calipers (custom powder coated), EBC GD Sport Drilled and Slotted Rotors, EBC Redstuff Brake Pads Aesthetic: Debadged | Cleared Front and Rear Corners | Red Rear Turn Signals | Bright White LED Reverse Lights | Black Centerpiece | Black Pontiac Emblem | 35% Huper Optik Tint | GXP Interior (Carbon Fiber Vents and Handle Inserts, Stainless Handles, Shifter, Black Buttons for Windows and Cockpit, Cupholders) | Hood and Rear Quarterpanel Herpes :thumbdown:
sextrosgxp
Re: Need new brakes, what brand?
Post by sextrosgxp »
I used Autosports rotors, ebc red stuff pads, and painted up a new set of calipers. Look awesome and work great. Don't waste your money on Brembos. Not even sure you can get Brembos or baer kits for these cars.
2005 GXP in Black
K&N Filter, tinted windows, tinted headlights, RVinyl fog light covers, Autosport cross-drilled and slotted rotors, EBC Red Stuff pads.
2012 Ford F150 FX2 Super Crew (Daily Driver) 5.0 V8.
There are no kits for these cars. You can take full advantage of the factory brakes by upgrading to some ceramic pads for greater bite. I have Hawk HPS and the bite is still amazing after 40k miles. They are a bit dusty however.
If you want to upgrade the calipers you can try to find GXP brakes, or you can try to adapt F-body calipers or C5 Z06 calipers. They need their caliper bolt holes redrilled for the H-body hub. But after that it's plug and play. I have a set laying around waiting for warm weather.
Zeik75
Year and Trim: 1988 LE
Post by Zeik75 »
F body Camero brakes are dual piston I believe and will bolt in. They are aluminum too so you could get a set from the junk yard and paint them. I believe there will be a little more pedal travel because of the increased volume but it should stop better. I have heard good things about slotted rotors and hawk? (Maybe) ceramic pads.
Corvette c5 brakes will work too but idk how much better than f body's those
Would be.
-Austin-
No one makes a bolt-on aftermarket brake setup, so that's out.
What can be done is to put together a setup using factory pieces from other GM cars. One method is to use F-Body (98-02 Camaro/Firebird) dual piston calipers and stock size rotors, another is to upgrade to Bonneville GXP/Cadillac DTS/Grand Prix GXP dual piston calipers and 12.9" rotors. There's been a lot of threads, a quick search on here would probably garner a lot of information. Some of these were red painted OEM, but you're probably going to want to give them a fresh coat of paint.
SSEi95
Site Owner/Webmaster
'01 Sierra C3
Post by SSEi95 »
http://www.pontiacbonnevilleclub.com/fo ... 41653.html
Andrew has a set of red GXP calipers listed.
Brakemotive on ebay sell zinc plated cross drilled and slotted rotor/pad sets for really cheap. I have a set and they seem to work well and reviews across the site are pretty favorable as well. Get those to match whatever setup you pick.
crash93ssei
Post by crash93ssei »
I have a brakemotive ebay setup on my SSEi in stock size and am very happy with them.
Zeik75 wrote:F body Camero brakes are dual piston I believe and will bolt in. They are aluminum too so you could get a set from the junk yard and paint them. I believe there will be a little more pedal travel because of the increased volume but it should stop better. I have heard good things about slotted rotors and hawk? (Maybe) ceramic pads.
Would be.
My setup is the slotted rotors and Hawk Ceramics. First time I stopped after the install it blew my mind. And ripped my sunglasses off my face. Hahaha.
F-body brakes will not bolt in. C5 Z06 brakes have bigger cooling fins and smaller pistons. They preserve the brake feel better than the F-body calipers do.
xyeLz
Post by xyeLz »
Okay. So I will get GXP calipers, Brakemotive zinc plated cross drilled and slotted rotors, and hawk ceramic pads? How does that sound?
What size rotors will I need? Does stock work with the GXP calipers? Should I get something bigger?
GXP calipers require stepping up to the larger rotors. You also need the hardware for the GXP calipers, they use a special shouldered bolt to bolt to the knuckle, and the brake lines may or may not be different.
xyeLz
Post by xyeLz »
Oh. Can anyone here comment on the brake lines? Would the shouldered bolt come w the calipers? What size rotors are GXP front and rear?
2000Silverbullet
Post by 2000Silverbullet »
Cheap Power Slots with ceramic brakes FTW
GXP rotors are 12.9" front, 11.9" rear, IIRC.
It *should* come with the calipers, but may not, so pay attention. I know the GXP brake lines were different, but I can't comment that your SSEi lines wouldn't work.
My question is: What are you stopping for? Just DD'ing the car? Or planning on doing some "high-performance" driving?
xyeLz
Post by xyeLz »
00Beast wrote:GXP rotors are 12.9" front, 11.9" rear, IIRC.
Really just stopping, but occasional hard use in summer only. I'd like to get the GXP calipers so whatever I need to do to make that work. I'll ask Andrew if his set comes with the bolt. I know this is a LMGTFY moment, but could you link me to the Brakemotive drilled+slotted rotors? I can't find them online... Also not sure which Hawk Ceramic pads to get?
SSEi95
'01 Sierra C3
Post by SSEi95 »
http://www.ebay.com/itm/FRONT-REAR-4-PE ... e1&vxp=mtr
Here is a complete pad and rotor kit for the 2005 Bonneville GXP. These should work with the GXP calipers on your car, but I would double check still.
sextrosgxp
Look under the GXP section and topic is Powdercoat Calipers. Gives a write up and pics.
2005 GXP in Black
xyeLz
Post by xyeLz »
Oh great, thanks. What about the brake lines. Should those be all set on my car and where can I find the Hawk Ceramic pads?
xyeLz
Post by xyeLz »
Okay just purchased the GXP calipers from Andrew! He mentioned that they come with the shoulder bolt as well as the brake lines. I can purchase the rotor set but it would be a shame to waste those brake pads. Are the Hawk Ceramic pads really a big step up?
How do I check to make sure they will work?
2000Silverbullet
Ceramic pads or go home! Of course they will work just fine and keep your wheels dust free.
crash93ssei
Did you get the rear calipers and brackets as well? The GXP uses a different caliper bracket for the rear and a larger rear rotor so if you don't get rear stuff you will need to make sure to get GXP front pads and rotors and SSEi rear pads and rotors.
