Battery heater help?
ricosuave420
Year and Trim: 1993 ssei supercharged bright white
Post by ricosuave420 »
Hi all, since it's going down to the single digits here in nj I wanted to get a battery heater for my car but no idea what I'm looking for, what's a good brand? What's a good size, is 8 1/2 by 11 1/2 big enough for an average battery? And I don't wanna wait for it to ship so is there a place that I can go to and just buy it, that is the right size and good brand of course.
Thanks for the help
1993 SSEI SUPERCHARGED AKA "ANGLE"
180,000 MILES
2000 WATT SYSTEM, ALPINE 7 INCH FLIP OUT TOUCH SCREEN TV, 2 12" SUB WOOFERS IN THE TRUNK
2000 WATT ALPINE AMP
LADIES CALL IT A ROLLING CLUB, I GUESS THE VIBRATIONS GET THEM READY FOR SOME FUN
SSEI= SSEXI
NOW WITH BEAUTIFUL BLUE NEON UNDERGLOW
CERTIFIED EAGLE SCOUT MAY 19 2009
REFERRED TO BY EVERYONE AS JAMES BONDS WEEKEND CAR, REFERRED TO BY ME AS ANGEL
Franksdad
Year and Trim: 2001 SLE
Re: Battery heater help?
Post by Franksdad »
i've never heard of a battery heater, i'm right up here with you in ny and i've never needed anything to heat my battery
2001 SLE tints | Series III L26 | 180 T-stat |
2002 Monte carlo SS Dale Earnhardt edition (waiting on salvage title)
ricosuave420
Well last week we had a full house for Christmas so after work I couldn't park in the garage as usual so I let it sit out in 20 degree weather and when I needed to move it the next day it certainly had a hard time starting, I know they sell engine block blanket heaters but they are like 300$ and since I just switched from 10-30 to 5-30 I'm not as worried about the engine but the battery it way more susceptible to the cold so that's why I'm looking for one
180,000 MILES
SSEI= SSEXI
SSEiMan01
Post by SSEiMan01 »
The 92-99 have batteries under the hood, the 00+ are under the back seat, where they stay a little warmer most of the time. I don't know much about battery heaters, but I'm sure someone here does.
James May wrote:Hello.
ricosuave420
Well I hope someone helps soon, on Friday it's supposed to be a high of 16 and a low of 7
180,000 MILES
SSEI= SSEXI
MattStrike
Year and Trim: '99 Montana
'92 Trofeo
Post by MattStrike »
Battery should have no problem cranking in 0 degree weather..
Merrillspontiac
Year and Trim: 2000 Pontiac Bonneville SE
Post by Merrillspontiac »
Your battery may be a bit weak.
1993 Buick Regal GS Coupe
Yeah.. I think the issue here is the battery not the temperature. The car shouldn't have issues with 7 degrees. It might take a second or two longer to crank, but that's normal. Cold engines don't like being awoken from their slumber.
RJolly87
Post by RJolly87 »
I have to agree, you shouldn't have any problems at zero. I have been there once at sub zero (barely), and sure the car cranked a bit slower, but I didn't feel in danger of being left behind either. But then again, I also try and run too much battery for the car.
bobtaz13
Year and Trim: 2001 SSEi
1991 SE
Post by bobtaz13 »
Mine is start just fine at -15, might take a little extra but no issues.
Think it's time to save up for a new battery.
2001 SSEi | Galaxy Silver | GenV supercharger P&P | Intense 3.2 MPS | Intense FWI 4"| Custom PCM | TOG Ceramic headers | Magnaflow 3" cat | 180° stat | Aeroforce scan gauge | PRJ plug wires | PRJ fuel rails | Silicone vacuum lines| AP103 plugs | 3.2 MPS | 42.5# injectors | Intense 1x cam kit | YT 1.8 Rockers | 105# springs | Meziere HD pump | N* Tb | 185mm MAF | 2" Phenolic Intercooler | Oil pressure kit | L32 short block | 5% overdrive SFI Balancer | L67 heads custom ported | EBC USR Rotors | EBC Red stuff pads | Custom HID Fog lights, with HI-beam over ride | Polyurethane motor mount | Energy Suspension end links | GXP Shocks/Struts | Custom Drop springs Front, Rear FE5 Springs | GXP Strut tower Brace | GP GXP 18x8 Rims | Polished Exhaust tips | Triple Edge High Performance Street/Strip 4T65E-HD |
2003 SSEi
Year and Trim: 2003 SSEi.
LOTS of Mods
Post by 2003 SSEi »
GM Accessories makes a battery heater..
viewtopic.php?f=8&t=16078
DaMaroon
Year and Trim: 2003 SE
Post by DaMaroon »
I'd spend the money to get the battery, charging system and starter checked/repaired. Having a car with a warm battery that won't start will really be painful. Most likely just a less than perfect electrical connection. I'd make sure all were shiny bright before going further.
crash93ssei
Post by crash93ssei »
Supposed to be -7 here in a few days with a wind chill of down around -15, I have never run an auxilary heater of any type before and have never had problems starting in the cold unless a bad battery was the issue. With a good battery you should have no problem starting the car with temps even a bit below 0.
arrowhead2001
Post by arrowhead2001 »
The lowest I've had to operate the car this winter in was -7F. It started slow but fine. No block or battery heater and parked outside.
DaMaroon
Post by DaMaroon »
Had an HEI ignition module go out when it was -27*. Cranked "fast" enough was expecting it to start. Luckily it was at work. Got a ride home and was able to let the van set a week until it was "warm" enough to work on it. On the G10 could work on it sitting in the drivers seat or it'd probably been longer.
Still the all time record low for here. (Yeah, I hear those in MN and CAN laughing)
ricosuave420
Seriously? U guys don't think it's the cold, that it's just a weak battery? Bc my moms 07 Avalon failed to start yesturdsy and today, but the hearty American war horse, my baby, started just fine and had to jump it both times. So u guys suggest getting a new battery?
180,000 MILES
SSEI= SSEXI
It depends. A battery heater also requires you to plug it in, something that's unlikely in a parking ramp.
When it's below zero, yeah it's not going to start right up. Might not be a bad idea to have your battery tested, see how many cold cranking amps it's still putting out.
My car has been starting just fine here when it's been this cold. Granted the G8's battery is in the trunk, but still plenty cold back there.
crash93ssei
Just know that when it is crazy cold like this, vehicles will take longer to start and will crank slower. Yesterday morning my truck rolled over slow and took a bit longer to fire up, when it did fire it died after a second. Kit the key again and it rolled over slow again but fired up fine and stayed running no problem. It was now slow to where I thought it wouldn't start, just slower then normal due to the cold.
