Piston question
bonniegirl
2003 GMC Envoy SLT
Piston question
Post by bonniegirl »
Ok so for my rebuild Im doing on my 2000 Bonneville SSEi what would be the best pistons to use?
2003 SSEi
Year and Trim: 2003 SSEi.
LOTS of Mods
Re: Piston question
Post by 2003 SSEi »
Stock Low milage.
redzmonte
Year and Trim: 2000 SSEI
Re: Piston question
Post by redzmonte »
New Stock, Unless you are going some crazy motor build then you can get Forged pistons from venders like ZZP or Intense.
S
Shane "RedZMonte"
2004 Z16 Z06: Virgin
MattStrike
Year and Trim: '99 Montana
'92 Trofeo
Re: Piston question
Post by MattStrike »
Depends on if it has to get bored over or not. If bored over then I'd get OEM replacements from ZZP. If it's not bored over, then :withstupid: low mileage used.
bonniegirl
2003 GMC Envoy SLT
Re: Piston question
Ok so if Im putting in a VS cam and intake and possible headers should I go with the forged ones or just stock?
MattStrike
'92 Trofeo
Re: Piston question
Stock, unless you're changing compression. Because once you change the pistons to something other than OEM/stock replacements (different weight) you have to get the rotating assembly re-balanced (machine shop work).
deano55
Re: Piston question
Post by deano55 »
new sealed power pistons are going to cost you around 450 dollars. std. bore
deano55
Re: Piston question
Post by deano55 »
bonniegirl wrote:Ok so if Im putting in a VS cam and intake and possible headers should I go with the forged ones or just stock?
if you are doing mods, you should have headers
