M62 By-Pass elbow
- Squilliam
- SSE Member
- Year and Trim: 1995 Park Avenue Ultra
M62 By-Pass elbow
So I've been searching and searching and cant seem to find anything on it. Called my GM dealer and they cant find it either. The 45 degree by pass elbow I have is way past its expiration date and is currently held together with electrical tape and red RTV. I would love to source either a new one or a good used one. I tried Using standard vac line, but the space and angle it bends makes it kink so there's a noticeable restriction on it. Thanks ahead of time for the help!
2002 Dodge Intrepid "Superbee"
- yourgrandma
- Year and Trim: '02 SSEi
Re: M62 By-Pass elbow
If its anything like the ones on my m90s, silicone tubing is better at bending without linking and should do the trick.
- MattStrike
- Year and Trim: '99 Montana
I agree, but if you can't find silicone to your liking, they sell generic vacuum 'T' and elbow fittings at most parts stores and you can use generic rubber vacuum hose for the straighter sections. I've also used painted steel brake and fuel lines and used clamped rubber hose on the ends, but they aren't good for super tight turns (done right they look good though).
- J Wikoff
- Year and Trim: 1992 SSE
Have you looked at mcmaster carr?
deano55
- Posts like an L36
- Year and Trim: 2003 Bonneville SSEI
have to try that guy in the Bronks that has a tv show, he says he can get anything. period. lol. rockauto?
