Car randomly stopped running.
rique8405
Post by rique8405 »
So about 20 minutes ago my car refused to run. It will turn over then die off with a popping sound. If i give it gas it will run as long as I keep my foot on the accelerator. It has gas and the oil is not low. I do need new plugs and wires which I have plans to get done on Saturday. Car is a 2002 SLE with 99978 miles. Any ideas what the problem might be?
RJolly87
Re: Car randomly stopped running.
Post by RJolly87 »
First problem, this should be posted in mechanical. A moderator will go ahead and move this for us in a bit.
Second problem, what does the popping sound like? Metallic? Backfire? If you disconnect one of the vacuum lines, do you smell gas in the vacuum lines?
rique8405
Post by rique8405 »
Sorry for posting in the wrong section. It was the fuel vacuum harness. Has been taking care off. However the car does have a very high idle. Believe that will be taking car of when I put on new plugs and wires.
crash93ssei
Post by crash93ssei »
Fuel vacuum harness? Was there fuel in the vacuum lines? If so replace the fuel pressure regulator immediately!
