Things in the night. - engine damage and pics pg 2
Re: Things in the night.
That's a clean looking GXP interior considering the price of the car. At least the suede still looks clean.
gweg_b
01 Bonneville SSEi
09 G8 GT
Post by gweg_b »
I would kill for a GXP in that condition, and for that price!!
Nice score, Ryan, can't wait to see what you do with it!
crash93ssei
Post by crash93ssei »
Well, I can't say for 100% sure yet, but I think I can get it running. Messing with it outside and it does fire and I even had it somewhat running at one point. I think a big part of the problem is bad gas. It just smells bad to begin with and then also I used the drain valve on my fuel pressure gauge and the fuel looks brownish when sitting on a white background. Raining now so not gonna do anything more until tomorrow, but gonna drain more gas and get a better look at it. Also going to pull all plugs out and check them out.
I can't rule out yet though that the engine isn't junk. Until I see it running and know it runs good I will still assume the engine is junk.
samples08
88,000k
Post by samples08 »
:Drool: I was right it is Black on Grey Mhmm I will be defiantly be watching this post!
Member #3848
2002 Black Bonneville SE Sold But Not Forgotten
2002 White Bonneville SSEi Project car
repinS
Moderator
Moderator
Year and Trim: 09 G8 GT
Post by repinS »
hells yes :mrgreen:
crash93ssei
Engine is junk, pretty sure it jumped timing on the intake cam on the front bank, broke all the cam followers off the head, likely bent valves and all that good stuff.
Looks like it will be parted out, which is what I was assuming would happen right from the beginning.
repinS
Moderator
Moderator
Post by repinS »
Ouch, never heard of one doing that before. Seems like not quite as likely of a failure considering that it's a timing chain instead of a belt. Sounds like many miles of abuse with shatty/few and far between oil changes.
Keeping anything for yourself? :P
crash93ssei
Sounds like this isn't the first one this happened to either - http://www.cadillacforums.com/forums/ca ... 80485.html
crash93ssei
Pulled the front plugs and found they were like new clean but soaked in fuel, knowing they guy said he replaced the plugs and thinking the problem was ignition / bad fuel related this didn't surprise me. I didn't think he changed the back plugs though since they are literally such a major PITA to get too. I ended up getting them out and this is what I found.
While the plugs were out I figured I would run a compression check just to see what I had to work with before I went any further, zero compression on all front cylinders, I thought I was doing something wrong! Checked one of the rear cylinders and got 120 PSI, checked the front again and still nothing on any of them. I decided to pull the front valve cover to check for bent valves and right away I noticed something bad. When I got it all the way off this is what I found...
All eight intake valve cam followers were not even in place and just laying around in the head! Also noticed a long thin piece of plastic / broken chain tensioner.
So, needless to say looks like it will be parted out, so many good parts on this thing!
For some reason I didn't get a close up of the fourth wheel, forgot I guess :lol:
So, who wants some GXP goodies!
MattStrike
Year and Trim: '99 Montana
'92 Trofeo
Re: Things in the night. - engine damage and pics pg 2
Post by MattStrike »
I want the motor...
samples08
88,000k
Post by samples08 »
I want the whole car..... Pockets say no :banghead: GLWS!
Member #3848
I'd snag the door handles if I had the cash cause I miss mine. XD
That thing is pretty much immaculate.
yourgrandma
Year and Trim: '02 SSEi
Post by yourgrandma »
Looks like you have about $3.2million in parts if my quick mental math checks out.
1tinindian
Year and Trim: 2004 SLE Premier Edition
2005 GXP
Post by 1tinindian »
Man, with that thing is in such good shape, I'd put another engine in it and drive the wheels off it.
To bad that it gets parted out, makes a rare car even more so, for the ones that survive.
Good luck with it!
Leon
2006 GTO
2005 GXP Bonneville (his) (SOLD)
2004 SLE Bonneville (hers)
2004 SLE Bonneville (sons)
2006 GXP Grand Prix (sons)
1998 SLE GMC Sierra
1991 Yamaha FJ1200
1983 Trans Am (SOLD)
1979 Trans Am
Wes
Post by Wes »
I would love so much to put gxp rims on the Olds. I hate being broke, lol.
Since you are looking at a swap anyway, why not make that the donor body for the L67 instead of the SE? What am I missing?
yourgrandma wrote:High
Wes
Post by Wes »
MattStrike wrote:I want the motor...
Explain yourself.
1tinindian
2005 GXP
Wes wrote:I would love so much to put gxp rims on the Olds. I hate being broke, lol.
+1
2006 GTO
1998 SLE GMC Sierra
1991 Yamaha FJ1200
1979 Trans Am
I think a cleaned-up N* block would make a great coffee-table base!
But yeah, seriously, why not fix up the GXP and pull a haro? Throw a cheap L36 in the SE and flip that, and then have the GXP and the SSEi...
SSEiMan01
Post by SSEiMan01 »
I'd take it for a table! :D
James May wrote:Hello.
gweg_b
01 Bonneville SSEi
09 G8 GT
Post by gweg_b »
Yeah, if you're parting it out, I'd love the door handles, steering wheel (with buttons), and the pedals, but I agree with the others, drop an L67 in there!
