Drivers rear door inoperative
Bad67bird
Year and Trim: 2000 Bonneville SE
Post by Bad67bird »
So the drivers rear door has two issues:
1.the window will not go up or down
2.the electric lock will not work (manual works fine)
so after some research it looks like there may be a door module that
needs to be replaced?is it possible that its a wire issue?or could i
just be unlucky and both the motor as well as the door lock actuator
went bad.
1967 Firebird 400 (stock looking but not)
2000 Bonnevile SE (plain)
2004 Grand Prix GT (mildly modded)
AJT2004
Re: Drivers rear door inoperative
Post by AJT2004 »
Did you check the driver's window lock-out switch? That would prevent the window from working for the passenger but it would work from the driver's controls. For the lock is the child lock override engaged? That too would prevent the passenger from electronically unlocking the door
Bad67bird
Post by Bad67bird »
AJT2004 wrote:Did you check the driver's window lock-out switch? That would prevent the window from working for the passenger but it would work from the driver's controls. For the lock is the child lock override engaged? That too would prevent the passenger from electronically unlocking the door
hey thanx for the response: all other doors work from both the drivers controls and there individuale spots.......even when i use the remote,the door lock does not work.That door only.
96 SSEi
Post by 96 SSEi »
hi, I would remove door panel and check for power and loose/fried connections.
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
Bad67bird
Post by Bad67bird »
96 SSEi wrote:hi, I would remove door panel and check for power and loose/fried connections.
that will be my next step ,thanx
ddalder
Post by ddalder »
There have been several incidents of the main 12V supply wire breaking in the rubber boot between the door and body. It will be the only heavy gauge orange wire in the bundle. The insulation may or may not broken but since it is such a heavy wire, bending in such a confined area it is prone to breaking over time. I would probably start there.
Arrowhead
2005 GXP
Post by Arrowhead »
I'll have both of the rear doors simultaneously stop responding to input from the driver's controls and the keyless entry fob. It comes and goes. I suspect that it has something to do with past water leaks, not sure.
ddalder
Post by ddalder »
Arrowhead wrote:I'll have both of the rear doors simultaneously stop responding to input from the driver's controls and the keyless entry fob. It comes and goes. I suspect that it has something to do with past water leaks, not sure.
In your case, I would start by looking for corrosion at a splice under the driver's seat. Look here under the Interior -> Passenger front and both rear door windows & locks don't work...
http://www.pontiacbonnevilleclub.com/fo ... 25362.html
This doesn't necessarily have to involve all three doors, but can. It depends on the extent of the corrosion.
Arrowhead
2005 GXP
Post by Arrowhead »
Thanks for the tip ! I'll check it out.
