Brake Line Repair Idea
JohnR
Year and Trim: 1997 Bonneville SE 40th Anniverary
Post by JohnR »
I had one of the brake lines on the driver's side frame rail by the trans let go yesterday. Anyone ever replace one of the hard lines with a pair of inverted flare to 3AN fittings and a piece of pre-made 3AN braided brake hose? I'd like to replace all of them with copper-nickel line in the spring, I have the tools and have made lines before but this looks like an easy yet safe way to get back on the road until the weather improves in a couple of months. There's a huge speed shop local to me that stocks all these fittings and hoses.
Adapters:
http://m.summitracing.com/parts/ear-591 ... Hwod1DIL7Q
Thoughts?
haro1225
Year and Trim: 2004 GTO
Re: Brake Line Repair Idea
Post by haro1225 »
Sounds like a lot of extra time and money if you're going to be replacing them all anyway. Just get a copper line and replace the whole line and that'll be one less you will need to do come spring. At the very least just replace it with a steel line. I had a line pop on me and I replaced it for $8 total.
-Ryan
2013 Audi Allroad Quattro
yourgrandma wrote:Hi.
96 SSEi
Post by 96 SSEi »
Hi, I agree, Fix with coated steel and flare and use union as usual and it will last years and be under 20 bucks for the line
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
MikeKerr
Post by MikeKerr »
Autozone and/or Advance Auto (can't recall) sell the pre-flared copper nickle lines, have to ask for them. Much easier to work with than steel for guys that don't bend pipe often, and with the pre flared you can typically bend the copper to make the length fit most applications.
MattStrike
Year and Trim: '99 Montana
'04 Dirtymax
'97 Camaro
'92 Trofeo
Post by MattStrike »
You don't want to use (braided) hose for any lengths longer than you have to, it's going to negatively effect brake pedal feel, and too much will cause not enough braking power.
Boost addict
The Fleet:
'97 Camaro - Top swap
'05 STS - V8, AWD, her DD
'92 Trofeo - Fair weather DD
'99 Montana - top swap 3800
Current project:
Something cool, trust me.
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
Gone to greener pastures:
'97 LeSabre - Top swap
RIP:
'86 LeSabre - pictures
'93 SE - L67
JohnR
Post by JohnR »
Finally got around to fixing it yesterday. Fortunately it was the one from the ABS pump to the LF wheel so it was the easiest of all of them. Made a new line out of cu-ni and called it a day. It was so painfully cold with the wind that I left the rest alone. If we get a warm spell soon I'll go out and do the rest.
I was going to say, you'd spend way more on AN-fittings and lines than just standard brake line...
