Fuel pump problems
1997SEgreenmonster
- SSE Member
- Year and Trim: 2003 BONNEVILLE SE
Fuel pump problems
I went and got fuel pressure tester and i notice that it say on box that it wont work on gm throttle body i got it a harbor freight
- crash93ssei
- Retired Moderator
- Year and Trim: 2002 SE
Re: Fuel pump problems
They are talking about the older throttle body injection systems, your car is fine.
1997SEgreenmonster
- SSE Member
what should the fuel pressure be with key on and what should it be the car started and driving
At least 45 psi. I believe around 50 is the norm. And it should be steady.
1997SEgreenmonster
- SSE Member
okay when i take the line off the FPR i can smell gas in it and its kind of wet could my FPR be bad too
- crash93ssei
- Retired Moderator
If there is gas in that vacuum line the fpr is bad for sure. Replace ASAP.
1997SEgreenmonster
- SSE Member
So I have a few problems with that fuel pressure tester
1. Its leaking really bad is there a way to stop it from leaking so i can get to test the fuel pressure
2. Is airtex a good fuel pump to use or delphi
3. So if i hold my finger over the FPR vac line for a few mins or seconds my finger becomes a lil damp and smell like fuel should I change the FRP ASAP
mrwildroot
- SSEi Member
- Year and Trim: 2000 Bonneville SE
You smell gas and finger wet from vacuum line to FPR?
Replace the FPR. Now.
- crash93ssei
- Retired Moderator
Where is it leaking, how about a couple pics? Also a few pics of the kit you bought.
1997SEgreenmonster
- SSE Member
crash93ssei wrote:Where is it leaking, how about a couple pics? Also a few pics of the kit you bought.
Its leaking from the top where you screw the on to the fuel rail and at the top by the gauge
- crash93ssei
- Retired Moderator
Make sure the fittings are good and tight and there is no O rings missing that should be there. If that all checks out it may just be a bad kit.
- Jfridge92
Definitely get the regulator changed as soon as possible. When they leak through the vac lines, they've been known to dump gas into the upper intake, and it can explode when starting the vehicle.
That's weird that your kit is leaking, my dad has the same one and we've never had any issues with it. +1 on checking for tight connections and missing o-rings, if it still leaks, see if harbor freight will swap you for a new kit. They've been good in the past about helping me with bad stuff out of the box in my area.
Joseph
1999 Infiniti G20T - Sold
1997SEgreenmonster
- SSE Member
So now when i start my car it feels like it wants to die and idle rough for like 10-20 seconds then it will idle fine
1997SEgreenmonster
- SSE Member
I had the check engine light come last night but when i got up to take it to get the code pulled for it today the check engine light went off
- crash93ssei
- Retired Moderator
The code will likely still be stored and you can scan it and retrieve it.
