I need some help! Intake gasket problems
Moparchevyandy
Year and Trim: 1997 Pontiac Bonneville SSEI
Post by Moparchevyandy »
Hey guys, Ive got a 97 Bonneville SSEI supercharged....
The car has been getting a slight amount of water in the oil every 3k miles, not too much, but enough to cause me to replace the intake gasket. This is what I assumed to be the problem.
So I replaced the intake gasket, and apparently I screwed up the installation. It smoked really bad afterwards. (white smoke, vapors out of tail pipe)
With me working a 50+hour week, I dont have time to re-do it, so I took it to a dealership to be fixed. They installed a intake gasket, telling me I done a perfect job and dont know why its messed up. After the installation, it still smokes as bad as when I screwed it up the first time. They are telling me its a head gasket, how would that be possible if the head gasket was okay before I screwed up the gasket the first time? :dontknow: Could they have possibly screwed it up as well?
Need some help guys, this is my DD! :sad:
Re: I need some help! Intake gasket problems
Was the car ever overheated? Although extremely unlikely, it could have been the head gasket all along.
Moparchevyandy
The car has never overheated since I've had it. It was running excellent before I fudged up the intake gasket. I was only changing the intake gasket for preventative maintenance. Otherwise the car was doing fine, not smoking whatsoever
pbrktrt
Year and Trim: 1995 Buick Riviera SC
Post by pbrktrt »
It's very likely a bunch of coolant got into the exhaust and will take time to burn off. Head gaskets are almost unheard of in these engines.
MattStrike
Year and Trim: '99 Montana
'04 Dirtymax
'97 Camaro
'92 Trofeo
Post by MattStrike »
Bad head gaskets usually result in misfiring, vibration under mid to heavy throttle, and consumption of coolant, if you're lucky enough to get it started.
Are you loosing coolant?
Boost addict
The Fleet:
'97 Camaro - Top swap
'05 STS - V8, AWD, her DD
'92 Trofeo - Fair weather DD
'99 Montana - top swap 3800
Current project:
Something cool, trust me.
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
Gone to greener pastures:
'97 LeSabre - Top swap
RIP:
'86 LeSabre - pictures
'93 SE - L67
Moparchevyandy
Car runs 100% perfect minus the smoke and mixing oil and coolant. Starts up fine and no vibrations.
Jfridge92
Post by Jfridge92 »
This may be a stupid question, and I may have missed it in another post, but did you only replace the upper intake gasket under the plenum, or did you replace the lower gasket under the lower intake manifold as well? If you didn't replace the lower manifold, that's the one that usually dumps coolant in the oil. Just want to help you rule out all possibilities, as like everyone has said head gaskets are rare on this car. However, if you did replace the upper and the lower intake gaskets, then it could be a head gasket.
Joseph
1999 Infiniti G20T - Sold
Moparchevyandy
Installed lower and upper gaskets. The head gaskets were fine before I screwed up the intake gaskets the first time :dontknow: maybe its possible the "professional" at Chevrolet screwed the install up too lol
MattStrike
'04 Dirtymax
'97 Camaro
'92 Trofeo
There really are not many ways for the coolant ot get into the combustion chamber. It's possible that the boost is masking the normal head gasket symptoms, or that there is a crack in the LIM or something like that.
Boost addict
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
