It is currently Sat Oct 11, 2025 11:45 pm
 Post subject: Fuel additives
PostPosted: Tue Jul 30, 2013 11:58 pm
Year and Trim: 2002 Pontiac Bonneville SSEi
Member #8782
Is there any truth to them? I've got a friend that says it helps tremendously, and another that swears its useless.
On a semi related note, is gas with 10% ethanol ok to put in? The pumps where I go have this and I noticed its a higher octane rating, which is really enticing, but I've been worried it could wreak my engine. What gives?
Kelvin VanderVeen
PERFORMANCE MODS
180 DEGREE THERMOSTAT, AUTOLITE 104'S, ZZP VOLTAGE BOOSTER
APPEARANCE MODS
LED INTERIOR LIGHTS, TAN INTERIOR TRIM, CLEARED CORNERS
:bpylons:
 Post subject: Re: Fuel additives
PostPosted: Wed Jul 31, 2013 12:47 am
Year and Trim: 2K1 GTP
Ethanol is helluva additive.
Just Your Average open loop tuned Ethanol Driven DD's
2k1 GTP: 13.307 @ 104: Headers, 1.9's, Tune
2k12 Impala: Stock
PostPosted: Wed Jul 31, 2013 11:30 am
It depends on the additive. Seafoam is a decent product and some others. Some, like octane boosters, do little, like .1 higher. What's the point of that?
Ethanol is fine to use, though MPG tends to suffer a little because of the lower energy content. Cars have been designed to handle it for twenty+ years. But regardless of ethanol content, you need to be using 91 or higher octane in your SSEi. It sounds like you run lower octane stuff, judging by your comments.
PostPosted: Wed Jul 31, 2013 6:08 pm
Year and Trim: 2000 SSEI
10% ethenal (E10) is noting to wory about. it makes emissions burn cleaner.. it acutally makes the Octain rating slightly higher... for example E85 is ~100 octain.. now your car cant run E85 but E10 is fine.. COlorado (where i live) and other states have that for cleaner emissions and like stated above you will get 1-2mpg lower with E10. I wouldnt run anything with more then 10% ethenal.
As for Additives these are very good proven products. dont waste your time with other stuff, most of it is a gimick.
BG 44K (Fuel injection cleaner every ~30-50K miles)
Seafoam (engine cleaner and fuel system cleaner)
GM Top engine clean (cleans heads, intake manfiolds, valves ect...) <--- SMOKES LIKE CRAZY WHILE ITS CLEANING SO DO OUTSIDE IN THE OPEN
Shane "RedZMonte"
2004 Z16 Z06: Virgin
PostPosted: Wed Jul 31, 2013 6:46 pm
Member #8782
The E10 at the station is rated at either 90 or 91 octane, I cant remember. Ill definitely start putting that in my car, though, thanks!
Kelvin VanderVeen
PERFORMANCE MODS
APPEARANCE MODS
:bpylons:
PostPosted: Mon Aug 12, 2013 7:15 pm
Year and Trim: 2000 SE, transg kit & B&M trans cooler
I use marvel mystery oil or trans fluid in my car, truck & sled keeps things clean while lubing the fuel pump & top end. Two ounces to five gallons on a regular basis in the summer
PostPosted: Mon Aug 12, 2013 7:34 pm
Also, many rave about Techron for its cleaning power. Seafoam is great, although I am coming to accept that it can be harsh as well.
If it's really bad, you plan to abuse it while using the product, and plan on doing a tune up after? Seafoam!
If you just want to clean out the works gently but effectively? Techron!
There are no new unread posts for this topic. 40+lbs Fuel injectors
MattStrike
Mon Mar 24, 2014 9:16 pm
There are no new unread posts for this topic. zzp fuel logs
95se
Fri Aug 16, 2013 8:42 am
There are no new unread posts for this topic. Air fuel gauge
99bonnie
Sun Nov 29, 2009 8:55 pm
98Park View the latest post
There are no new unread posts for this topic. Fuel Pumps
WhiteArrow3800
Wed Feb 01, 2012 8:41 pm
This topic is locked, you cannot edit posts or make further replies. low fuel pressure
spoiledred94
Sat Sep 06, 2008 1:11 am
willwren View the latest post
