It is currently Wed Oct 08, 2025 6:46 am
 Post subject: voltage question
PostPosted: Sun Jun 15, 2008 9:39 pm
Year and Trim: 1996 SLE - "Twilight"
Okay, so my volt gauge is reading irregularly lately. I replace the alternation and that fixed it for one start. Then it started doing it again. The gauge sits around 13 volts. If I give it gas, it drops to about 12. Any clues? I'm thinking that there is some sort of draw somewhere, but I'm looking for any other ideas. That seems like to a lot of juice to be going bye-bye from some sort of draw. Oh, and my speedo needle bounces when I hit the brakes.
'96 Bonneville SLE "Twilight" ( sold :( )
'72 Mustang Hardtop
'01 Grand Prix SE
'06 MINI Cooper S
'88 Ford Mustang Convertible (roller/for sale)
 Post subject: Re: voltage question
PostPosted: Sun Jun 15, 2008 10:30 pm
Year and Trim: 1993 SSE (NA)
I had a similar problem with the volt gauge going backwards when I would rev(stab) it in park. If I stabbed it repeatedly, I could actually "walk" it down 3 or 4 volts. I did 2 things that effected and fixed it.
1. First, by chance, I had to replace the battery because of stripping out the negative post. The new one reduced the drop by 50%.
2. Second, I believed that the voltage regulator was goofed up in the alternator. It was 7 years old, with a lifetime guarantee. But it still passed the Autozone test. The guy didn't know it was theirs and said he thought it had a bad front bearing, so I dropped it on them for a free replacement. Long story short, the new alternator fixed the rest the voltage drops (2 volts) with increased RPMs.
So, you might first ensure you have good cable connections with no corrosion inside the wire. If that is okay, I would be looking at the alternator.
PostPosted: Mon Jun 16, 2008 1:57 am
I still kinda think it's the alternator. This is exactly what the old one was doing. I took it out and they bench tested it. Bad voltage regulator. This one I just had them test it on the car. I should have known better. We did battery testing at wal-mart and the hand-held units were notoriously unreliable. Maybe I'll take it out again this week and have them bench test it again.
EDIT: btw, the new one is only a day old!
'72 Mustang Hardtop
'01 Grand Prix SE
'06 MINI Cooper S
PostPosted: Mon Jun 16, 2008 10:07 am
Beware that if they only test it at that one, idle-like speed, that it really doesn't test the regulator out to expose this problem. Something else; You may have seen some other posts here regarding the insides of the battery cables corroding. :shocked: You should look at that too, esp. near the positive post. You have to slit the insulation and peel back; then tape it back up if okay.
PostPosted: Mon Jun 16, 2008 10:13 am
Assuming you didn't get a bum alternator I suspect the battery too.
and as mentioned check those cables for any corrosion.
Bone Evil
Mods: Tog Headers, cat delete, Al 104's gapped .050, 1.9 rockers, 105 springs,
Intense FWI, DHP Power Programmer PCM, Intense tranny with gen2 lsd,
Aeroforce scan gauge, Clear front and back, N* TB & LQ4 Maf,
Hoosier slicks, ZillaMotorsports P/P GenV & LIM
Pisco_Paul wrote:
Every time you pat my head, you pat a piece of my valve retainers.
There are no new unread posts for this topic. No charge voltage, Low idle voltage, Check Charge System
03maroon
Sat Nov 19, 2011 4:08 pm
03maroon View the latest post
This topic is locked, you cannot edit posts or make further replies. 15+ Voltage!!
BFF_Larry
Sun May 22, 2011 11:01 am
willwren View the latest post
There are no new unread posts for this topic. Normal voltage
MStokes
Fri Nov 07, 2008 10:51 am
lunchboxx View the latest post
There are no new unread posts for this topic. Voltage drop
78elcaminoman
Tue Oct 28, 2008 9:27 pm
78elcaminoman View the latest post
There are no new unread posts for this topic. raising voltage?
BFF_Larry
34
6092
Fri Jun 24, 2011 10:01 pm
Bugsi View the latest post
