It is currently Wed Oct 08, 2025 4:53 am
PostPosted: Thu Jun 18, 2009 10:46 pm
Year and Trim: 1999 SSEi
My security light stays on. It started one really cold day in winter and now it wont go away. The car functions fine with it on - all doors lock with the remote, and all doors will set off the alarm (if opened when the car is locked).
I have tried disconnecting the battery for a day.
Any ideas what to do?
Thanks
PostPosted: Fri Jun 19, 2009 11:34 pm
Year and Trim: before cars
May be an ignition lock cylinder that the security wiring is partially broken. still making contact in crank position but not run position.
PostPosted: Sun Jul 05, 2009 7:25 pm
My parents 99 SSEi does the same thing... They don't seem to mind it being on..
2005 Bonneville GXP Fully Loaded
PostPosted: Sun Jul 05, 2009 10:23 pm
Year and Trim: 99 SSEi
01 SLE
02 GTP40th
02 SSEi
06 GP GT
same thing here most the time. Sometimes goes away for awhile then comes back for a while.
DHP Powrtuner & Tech 2
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
2002 GTP 40th Anniv Ed Coupe
PostPosted: Sat Jul 18, 2009 4:03 pm
The most likely culprit is the trunk lock tamper switch. There's a small metal tab attached to the trunk lock tumbler (where you put your key) that is designed to let go (or release a cable) if the lock is tampered with. The cable actuates a switch by providing a ground, and setting the security light.
The easy fix is to simply disconnect the wire. You'll have to remove the trunk lid carpet (if equipped) to find it. It'll be between the 'layers' of the trunk lid itself. Follow the cable from the lock to the electrical (single wire) connector, and disconnect it at that point. Cycle the ignition once, and see if the light goes out, or simply inspect to see if the tab/cable has broken off the lock tumbler.
This is one possibility in a system that is very hard to troubleshoot, but is the most likely/common failure.
PostPosted: Mon Jul 20, 2009 7:31 pm
Thanks for all the replies. I disconnected the trunk tamper lock wire, but the security light is still on. Is there a similar wire for the driver's side or passenger's side key locks?
PostPosted: Wed Jul 22, 2009 11:12 am
Location: Phoenix, Arizona WCBF '05, '06, '07, '08 - NEBF '07
Year and Trim: 1997 SSEi
1993 SSE
There are many wires/connections that influence the security light. The FSM lists steps to track down the reason the security light staying on
Here are the beginning steps for the procedures:
Security light
System Check procedures -
To begin:
1. Put ignition switch in RUN position (engine NOT running)
2. Close front doors
3. Unbuckle seat belts
4. Set park brake off
"SECURITY" indicator should light for approximately five seconds.
if "Security" indicator remains on or does not operate properly:
Perform PASS-II Diagnostic System Check:
- Check for PCM Diagnostic Trouble Codes
- Attempt to start vehicle
- Note "Security System" indicator while cranking engine.
Did engine start?
No or Yes
I am assuming your engine starts so we will say "Yes"
Did the indicator turn on for approximately 5 seconds then turn off?
No or Yes
I am assuming "No"
Did the indicator stay "on" steady (vs. flashing, i assume)?
No or Yes
If no, then:
- check indicator "lamp"/bulb
- Check for an open circuit in CKT 264
- If, previous 2 are ok, then replace PASS-Key II Decoder Module
If yes, then:
Go to chart #1
Chart #1:
- Ignition switch "off"
- Disconnect the "Pass-Key II Decoder Module Connector"
- Ignition switch "on"
Does security indicator turn off?
No or Yes?
if "Yes", then, Pass-key II decoder module is not programmed or there is a system malfunction while the engine is running. Refer to Chart #4. (I can add this later if needed)
if "No", then:
Is vehicle equipped with Universal Theft Deterrent (UA6)
if “No” to UA6, repair short to ground in CKT 264
if “Yes” to UA6, then disconnect "Remote Function Actuator (RFA) Module Connector.
Does "Security" indicator turn off?
Yes, then replace RFA Module (I can look this up, too, if needed)
No, repair short to ground in CKT 264.
WARNING: If you are going to disconnect the PKII module connector as described in Chart #1, then, I need to post a warning. FSM says disable SIR (airbag) system to avoid accidental deployment. The PKII module is either "under" or "Near" the passenger side airag. If you are going to start disconnecting PKII and RFA stuff, please disconnect the SIR. I don't want to be responsible for any bonne damage/personal injuries.[/quote]
"Really Not Stock Anymore" Bob and most recently renamed, "Chief BadLifter"
SingsCountry1967 wrote:
I can babysit your car for the week... or rent it.... I won't race it I swear <fingers crossed>
Best ¼ ET=13.674, Best 60’=2.122, Best Trap=102.26 mph Pacesetter headers (2.5" outlet), Magnaflow hi-flo cat, INTENSE FWI w/K&N 9" cone, ZZP XP cam, INTENSE OR pushrods, Comp 105 springs, Autolite 103 plugs, Stoppenbach tuned PCM
PostPosted: Tue Aug 18, 2009 8:58 pm
Year and Trim: 1999 Oldsmobile 88 LS
Something quick and might be an easy fix, is hold the lock and unlock button at the same time until the car beeps. It resyncs the remote to the car. Might not do anything to help your problem, or it might.
I have read about this before on websites and it means the VATS system is malfunctioning. Thats odd that everything still functions correctly with it on though. Reset your codes.
PostPosted: Sun Aug 23, 2009 4:15 pm
I tried that with no luck.
Thanks for the tip.
PostPosted: Sun Aug 23, 2009 8:38 pm
The VATS has 4 modes for failure. One of those is where the resistance changed so it goes into a mode where it doesn't work to turn off injectors and starter relay; it just ignores bad resistance reading from the key.
A quick try might be to bypass the VATS wires to the ignition lock cylinder with the proper resistors at the base of the steering column where the lock cylinder wires go into a connector. That might be your problem.
My 98 leSabre had the security light come on occasionally while driving. It had started sometimes requiring a second try to crank--it just didn't seem to get the reading from the key when I pushed the key in and quickly turned to crank. But it didn't lock out for 3 minutes. Then one day it just stayed on and car started fine. And later the light is off and never comes on.
Note, my car does not have the body tampering theft sensors. I ordered the car without that intentionally. That adds another factor to your troubleshooting.
I read that some people cut the wires to the lock cylinder with the engine running to fool the TDM into thinking it had failed and go into the do nothing failure mode. I can't recall the Bonneville discussion that was in and it was a couple or three years back.
PostPosted: Sun Aug 23, 2009 8:51 pm
I tried using my spare key, which is brand new since I haven't used it in 10 years, light is still on. Perhaps the system needs to be reset somehow to get it back into the correct mode?
I guess I should start working through the diagnostics flowchart that was posted above. I just have to figure out how to disable the airbags first before going poking around in the vicinity.
Dealer quoted me $200+ to diagnose and fix plus parts, which he said could be many hundreds $$.
Thanks
matt
There are no new unread posts for this topic. 1997 Bonneville, Security light stays on
Dan_in_WA
Wed Dec 07, 2022 9:06 pm
StraTact View the latest post
There are no new unread posts for this topic. Security Light On (Pass Key)
99ssei
Mon Sep 07, 2015 6:32 pm
cjski View the latest post
There are no new unread posts for this topic. Security light and car trying to die while driving.
Weekender01
Mon Sep 07, 2015 5:12 pm
There are no new unread posts for this topic. Security Light Intermittently Coming On
locowbl
Wed Jun 15, 2011 5:29 pm
locowbl View the latest post
There are no new unread posts for this topic. 2000 ssei security disabling starter?
evan
Sat Aug 31, 2013 2:02 am
evan View the latest post
