It is currently Fri Sep 12, 2025 4:11 pm
PostPosted: Fri Dec 04, 2015 5:46 pm
A grandson and I are attempting to replace the rear pads and rotors on the 2005 SE Bonneville. We have the driver side apart, but are unable to place the parking brake cable back onto the caliper (reman as we couldn't compress the old calipers). Any help would be greatly appreciated.
Hope this finds everyone well and that everyone had a great turkey day.
Thanks! - BC
PostPosted: Fri Dec 04, 2015 10:23 pm
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
If you use 2 pairs of diagonal cutting pliers or use 2 pairs of vise grips or 1 vise grip w/ 1 pair diagonal cutting pliers--put some electrical tape on the blades to avoid nicking the cables-- you can easily retract the spring from the cable end.
PostPosted: Fri Dec 04, 2015 11:40 pm
It's way easier to disconnect the front cable from the intermediate cable roughly below the the 'B' under the driver's side of the car. Once these are apart (which isn't too difficult), the other cables become much easier to disconnect and reattach to the calipers. To separate the cables at this joint, there will be a small tab that needs to be bent out of the way to slide the cable end out of the connector. When you reassemble, be sure to bend the little tab back again. Unfortunately I don't think I have a picture but it is pretty easy to figure out once you look at it.
PostPosted: Sun Dec 06, 2015 10:42 am
The youngest son and his buddy thought this was the best way to do it, but couldn’t figure out how to take the tension off the parking brake cable to undo the cables at the joint.
I couldn’t see how the youngest son and his buddy actually put the cables back on, but from the conversation if it wasn’t this way, it was pretty close to it.
I really appreciate the feedback from both. The car should be back on the road today. - BC
PostPosted: Sun Dec 06, 2015 4:51 pm
It was a royal pain in the ass. I had to do both rear calipers on both cars when I had the SSEi and the GXP, not too far apart, and it took me a good hour to get the first one. The last one took about 3 minutes, lol.
There are no new unread posts for this topic. Can't get parking brake cable back on rear calipers.
cpilkington
Tue Dec 23, 2014 7:51 pm
There are no new unread posts for this topic. Parking brake cable
Abbby
Mon Sep 02, 2013 12:08 am
Archon View the latest post
There are no new unread posts for this topic. right rear parking brake hanging up
Abbby
Thu Jul 04, 2013 12:03 pm
There are no new unread posts for this topic. Stuck Rear Brake Caliper Piston
fixitall
Tue Oct 12, 2010 10:50 pm
bslayer View the latest post
There are no new unread posts for this topic. Left rear parking brake inop
tracerprix
Mon Sep 19, 2011 9:16 am
tracerprix View the latest post
Users browsing this forum: No registered users and 17 guests
