It is currently Fri Sep 12, 2025 4:13 pm
PostPosted: Wed Nov 10, 2010 10:46 am
Year and Trim: 1997 SSEI
I need to replace the cooling fan relay. I have the part, and I know it goes underneath the hood below the "maxi-fuses", but there are 4 identical relays below the fuses and I don't know which one to replace. Any ideas or suggestions would be helpful. Almost forgot - it's a 97 ssei model.
PostPosted: Wed Nov 10, 2010 11:05 am
Year and Trim: 1999 SSEi
1997 SSEi-Resting-353K
the 2 to the right are cooling fan relays. the right most is low, the left is high.
PostPosted: Wed Nov 10, 2010 10:39 pm
The picture is only good if some smart-a$$ mechanic at the dealer didn't do the shuffle on you with them. Most of the mechanics at the dealer are a real joke. I do better work and I am not, I repeat, I am not a mechanic. Good Luck! - BC
PostPosted: Fri Nov 12, 2010 3:08 am
Thanks so much for the diagram! It makes things a lot easier.
There are no new unread posts for this topic. 95 lesabre abs relay
Troyport
Fri Jan 28, 2011 2:39 pm
willwren View the latest post
There are no new unread posts for this topic. ac control relay
mckcuzzi
Wed Jun 15, 2011 5:48 pm
mckcuzzi View the latest post
There are no new unread posts for this topic. relay center
mckcuzzi
Fri May 27, 2011 4:59 pm
sandrock View the latest post
There are no new unread posts for this topic. relay hot to touch
mckcuzzi
Tue Feb 28, 2012 7:41 pm
RJolly87 View the latest post
There are no new unread posts for this topic. Where is the starter enable relay
dreuxb
Tue Mar 24, 2009 8:19 am
93RedSled-SSE View the latest post
