It is currently Sat Oct 11, 2025 11:49 pm
 Post subject: Radiator upgrade issue
PostPosted: Tue Sep 28, 2021 6:59 pm
1992 Bonneville SSEi (Sold)
Hi All
My original radiator finally let go. I did some searching and read that the Olds aurora 3.5 radiator could fit. I ordered one for a 2002 Aurora and picked up a coolant bottle from the junk yard. Got everything in and together. I added a T fitting to the inlet heater hose to run the new bottle. I'm having trouble with coolant flow. The lower hose is staying cold. The bottle keeps filling up its not over flowing. At idle the temp is great at 185ish. Something when driving it will get to 220. I've checked and rechecked everything and not sure why it's not flowing.
Any ideas?
Thanks Keith
2001 SSEi Bumbles
PostPosted: Wed Sep 29, 2021 12:38 pm
You re-engineered the cooling system and didn't provide any links to what you did. I'm not even sure how to begin to help you. Post some pictures or more information.
PostPosted: Wed Sep 29, 2021 5:33 pm
I installed a new radiator from a 2002 oldsmobile Aurora 3.5. The lower and upper radiator hoses are the same. I also installed a new coolant bottle from the Aurora. For the outlet (bottom hose on new bottle) I tied it into the inlet heater hose with a T fitting so I could keep the original routing from the Alternator bracket to the firewall.. I removed the bleed valve on the thermostat housing installed a new fitting ran a hose from that to the top of the new coolant bottle. I will try to upload pictures tonight
2001 SSEi Bumbles
There are no new unread posts for this topic. Oversize radiator for 98 SSE
Nascarnuts
11
1879
Tue Jun 16, 2009 6:21 am
sandrock View the latest post
There are no new unread posts for this topic. ECM upgrade
phoenix_flame220
Tue Jun 23, 2009 11:53 am
clm2112 View the latest post
There are no new unread posts for this topic. Radiator header clearance
Pair of SSEI
Wed May 18, 2016 7:27 pm
Pair of SSEI View the latest post
There are no new unread posts for this topic. Radiator type intercooler
shredthebonnie
Wed Oct 21, 2009 5:45 pm
1994se View the latest post
There are no new unread posts for this topic. has anyone tried this Lucerne HD radiator swap yet?
prof. utonium
Thu Apr 30, 2020 8:46 pm
prof. utonium View the latest post
