It is currently Sat Oct 11, 2025 11:47 pm
PostPosted: Fri Feb 18, 2011 2:22 pm
Two quick questions:
1) Will L32 injectors be fine in an L67 with out tuning for it? I see the part numbers are different, but not sure what the actual difference is between them.
2) Out of pure curiosity as I have no reason to, anyone know if the L32 fuel rail would be a direct swap onto an L67 or would it only bolt onto an L32 LIM?
Last edited by WhiteArrow3800 on Fri Feb 18, 2011 2:23 pm, edited 1 time in total.
PostPosted: Fri Feb 18, 2011 8:35 pm
Fuel injectors are not compatible.
Neither is the fuel rail, L32 is a returnless system.
PostPosted: Fri Feb 18, 2011 10:12 pm
The L32 injectors are actually rated LOWER than L67 injectors. They are 30 lbs. versus 32 lbs. for the L67.
L32 rail will bolt on, but that's it. I plan on using one when I convert, but you have to use the fuel filter from a 99-02 Corvette (it has an FPR built in) or one from a 2004 Grand Prix (only year the filter was external and is built like the 'vette filter) in order for it to work.
BonneMe wrote:
There are no new unread posts for this topic. 40+lbs Fuel injectors
MattStrike
Mon Mar 24, 2014 9:16 pm
There are no new unread posts for this topic. If you need fuel injectors cleaned....
ytd1861
Thu Apr 25, 2013 4:20 pm
There are no new unread posts for this topic. sbc injectors
trf_ssei
16
2219
Thu Jun 26, 2008 9:41 am
BillBoost37 View the latest post
There are no new unread posts for this topic. N/A injectors
bonnevillain
15
3623
Sat Oct 17, 2009 10:01 am
Larz01 View the latest post
There are no new unread posts for this topic. Guess who needs injectors!
Allmachtige
15
1948
Thu Jun 04, 2009 10:58 pm
1994se View the latest post
