It is currently Sat Oct 11, 2025 11:49 pm
Post new topic Reply to topic  [ 17 posts ]
 Post subject: sbc injectors
PostPosted: Sun Jun 22, 2008 1:33 pm
Year and Trim: 1998 bonneville SSEi
Could I put 350sbc injectors in my L67 without making any other modifications? Would it work to generate more power or just create problems?
 Post subject: Re: sbc injectors
PostPosted: Sun Jun 22, 2008 1:53 pm
Just create problems.
Your pcm has an injector flow rate programmed in it. If your change the injectors, it's not going to fuel the engine properly.
You have to do quite a bit to max out your injectors too.
What mods do you have already?
PostPosted: Sun Jun 22, 2008 2:04 pm
None. well CAI but i dont plan on doing anything else except mabey a high flow cat and mabey a smaller sc pulley.. I just thought if it would be quick and easy than mabey injectors but, "if it was quick and easy everone would do it".. :bhuh: it was just a thought. The car is an every day driver so i cant really take it out of commission to do the mods required..
PostPosted: Sun Jun 22, 2008 2:06 pm
Plugging in fuel injectors isn't like jetting a carb. Different injectors require different flow rates programmed into the PCM as already mentioned, PLUS a boost in fuel pressure for the spray to atomize correctly.
Not to mention your L67 injectors are the same ones used in some V8s already.
BonneMe wrote:
PostPosted: Sun Jun 22, 2008 2:26 pm
Yes, the size and shape of the injectors are standardized to a certain extent. However, as mentioned above, you will not get the results you are expecting. If the injectors are off a TPI motor, they are 18lb/hr, off an LT1 motor I think they are 22lb/hr. With injectors off of either platform, somebody might have hot-rodded the motor and put in bigger injectors..always check the part number cast into the injectors. You can also send them off to be cleaned and matched up. There's a fellow in the Bonneville group who does this for a living.
PostPosted: Sun Jun 22, 2008 2:43 pm
Year and Trim: Sapphire -1999 SSEi Metallic Navy Blue
His name is Chris and here's the original post :wink:
http://www.bonnevilleforum.com/showthre ... +injectors
fuelforthesoul1999 wrote:
Sapphire, of course, god that's the automobile equivalent of Halle Berry, you just want her.......
Quote:
Without question, the greatest invention in the history of mankind is beer. Oh, I grant you the wheel was also a fine invention, but the wheel does not go nearly as well with BBQ!!
PostPosted: Sun Jun 22, 2008 6:52 pm
Is there any way to distinguish weather or not my injectors have a bad flow rate? And can one test the current through the injector circuit to tell if it is faulty or not..?
PostPosted: Sun Jun 22, 2008 7:16 pm
your injectors are fine up until you get to the rate that willwren's car is at, i believe, and that is a big amount of power for a 3800.
PostPosted: Sun Jun 22, 2008 11:35 pm
fine if they are working properly... he is wondering if there is a way to test them.
PostPosted: Sun Jun 22, 2008 11:54 pm
Bigger injectors don't add power. Ideally, if you're outflowing your injectors, a boost of fuel pressure would be the best 'first step' as the fuel will atomize more efficiently, and the flowrate will rise with higher pressure.
It takes alot of mods to need bigger injectors.
Unbolt the rail and put six identical shotglasses under each injector. Crank the motor several times and fill the glasses. Make sure they all look like the same level.
That's the best you can do on your own.
PostPosted: Wed Jun 25, 2008 7:13 pm
Ok thanks. will more fuel pressure make a difference, efficiency wise? like i said before its an everyday driver. With gas prices the way they are im looking for ways to get more power and increase my mileage but that is another topic..
PostPosted: Wed Jun 25, 2008 8:51 pm
With no 'flow' mods? No. Leave the fuel pressure stock and concentrate on a good tuneup. Most important? Tire pressure. Raise it to 5psi over suggested for your tires.
PostPosted: Wed Jun 25, 2008 9:14 pm
wont another 5 psi wear the center of my tires quicker and end up costing my in tires rather than fuel.
PostPosted: Wed Jun 25, 2008 9:55 pm
Not really so much on a stock width tire size. It will wear them slightly faster, but not to the point of it costing more in tires in the end. By the time the center is wore out, you will be in need of new tires anyways. If you were running a wide tire it would have an effect though. I have pretty much always run my tires at 40 psi and have never had a problem. You do get a somewhat stiffer ride and slightly better handling as well as the increased fuel mileage.
If you are worried about it though, you can just make sure that they are set at 35 and you will be fine. The mileage increase wouldn't really be massive with just 5 psi, but it would just be one more little thing that helps. As we all know, right now, every little bit counts.
PostPosted: Wed Jun 25, 2008 10:00 pm
Balance your fuel savings against a couple thousand less miles in treadwear and let your wallet decide. ;)
No tire on the market today will be hurt by 5psi over the AVERAGE suggested pressure.
PostPosted: Wed Jun 25, 2008 10:58 pm
alright thanks very much.. and crash has a good point now days" every little bit helps" I'll try that.. thanks again guys
PostPosted: Thu Jun 26, 2008 9:41 am
Year and Trim: 00 Regal
With your mods, your injectors should be the right size/flow rate.
If you were looking to increase flow, another possibility would be to have your PCM reprogrammed with scaled down injector sizing to increase flow. The pcm would pulse them more to compensate for their smaller size and it's fueling requirements.
97 Ei
97 GS
98 GS
There are no new unread posts for this topic. N/A injectors
bonnevillain
15
3623
Sat Oct 17, 2009 10:01 am
Larz01 View the latest post
There are no new unread posts for this topic. 40+lbs Fuel injectors
MattStrike
Mon Mar 24, 2014 9:16 pm
There are no new unread posts for this topic. Guess who needs injectors!
Allmachtige
15
1948
Thu Jun 04, 2009 10:58 pm
1994se View the latest post
There are no new unread posts for this topic. If you need fuel injectors cleaned....
ytd1861
Thu Apr 25, 2013 4:20 pm
There are no new unread posts for this topic. Flow matched injectors.
irish91983
Thu Sep 30, 2010 3:36 pm
willwren View the latest post
