It is currently Thu Oct 02, 2025 2:43 pm
 Post subject: Angel eyes
PostPosted: Sat May 02, 2009 4:09 pm
Year and Trim: 2003 Black SSEi
Wondering if someone can give me a bit more info on them. I know some members have them on there car. Do they glow on the outside? How hard would it be to put them in my 03?
 Post subject: Re: Angel eyes
PostPosted: Sun May 03, 2009 6:22 pm
Year and Trim: 1995 SSei
1987 GN 16K Original
They have a led ring on the outside and a fog ligh in the middle. You have an option to use either or on a switch. I know I bought mine from pfyc.com a few years back.
PostPosted: Sun May 03, 2009 10:49 pm
I haven't done them on the '00+ but from what I've read it would be similar to the '92-'99 install. All you will have to do (Mounting-wise) is bend the stock brackets (which can be done easily) and mount the angel eyes to that. The only complaint I had was the actual LED halo isn't all that bright. It can be seen at night, but there can't be much light around you. The fog lights themselves are considerable improvements over stock. I could see everything without the headlights being on, but that's illegal.
Last edited by WhiteArrow3800 on Sun May 03, 2009 10:52 pm, edited 2 times in total.
PostPosted: Mon May 04, 2009 1:59 am
Can you wire it up where both are on at once then right? Can you just splice the stock wires and hook them up to that?
PostPosted: Mon May 04, 2009 7:24 pm
As far as my '93 goes, I wired the fog lights to the factory switch. And I had a separate button wired for the LED rings. So yes you can wire them to come on at the same time. The wire diagram that comes in the instructions and the switch they provide allows you to turn on one or the other, not both. But this can easily be done to turn both on, or however you want.
If you want to be able to see the LED halo, I'd suggest wireing them separate. If you wire them both to the factory fog light switch and they come on at the same time you will barely see the halo if at all. Using another switch for the LED ring (like what they provide you with) you can turn them both on/off at the same time or one or the other. If you follow what I'm saying.
PostPosted: Sat May 09, 2009 6:57 am
Year and Trim: 2007 Impala SS
1997 LeSabre Limited
If this helps.....i wired my halo's into my park lamp wire.
Here's a pic.....again, theyre not all that bright during the day, this was taken at dusk.
2007 Impala SS - 30k 5.3L V8
1997 LeSabre Limited - 115k
Gone but never forgotten:
2001 Bonneville SE
1992 Bonneville SE
PostPosted: Mon May 11, 2009 11:25 pm
Year and Trim: 1999 Pontiac Bonneville SLE
I was thinking of getting some of these, are they really worth it? I have blue neons, i was thinking itd be nice to have the blue halos to go with it
PostPosted: Tue May 12, 2009 7:30 pm
ohhh they light up the road quite nicely
2001 Bonneville SE
1992 Bonneville SE
PostPosted: Sun May 17, 2009 12:32 pm
Yea I think I am gonna get these, but how hard were they to install in your ride? How many mods did you have to do?
PostPosted: Sun May 17, 2009 10:08 pm
I'll try to make this short and sweet...
The angel eyes come with a bracket that is adjustable with a 10mm bolt. I believe its a 10mm . Remove the bracket and take the holes and line them up with the bumper. This way you can drill new holes into the bumper for these lights to mount up. The OEM holes will not work, trust me. I actually found it best to mount them from the top of the bumper. Before you go and bolt up the lights, run your wires. I ran the halo wires behind the radiator support, i purchased some clips and screwed the clips into the rad support. Been working for 2 years NO problems.
Oh, for improved lighting...buy the Silverstar H3 bulbs....much brighter than the ones that come with the angel eyes. If you need help or pics i can try to go take some.
2001 Bonneville SE
1992 Bonneville SE
There are no new unread posts for this topic. Condensation in the angel eyes
ptrfair
Sat May 23, 2009 5:29 pm
ptrfair View the latest post
There are no new unread posts for this topic. These wonderful angel eyes
SLEking
Wed Jul 28, 2010 8:04 pm
Black Pearl View the latest post
There are no new unread posts for this topic. Headlight mods - angel eyes, nipple removal, etc.
radomirthegreat
Sun Sep 14, 2008 12:48 am
radomirthegreat View the latest post
There are no new unread posts for this topic. Angel Eye Headlights
Rapp16
Sun Jan 10, 2010 8:18 pm
Looong4 View the latest post
There are no new unread posts for this topic. Fly Eyes Light Tint
theax40
21
4128
Fri May 04, 2012 7:41 am
jonnevilleSSEi View the latest post
