It is currently Thu Oct 02, 2025 3:58 pm
PostPosted: Sun Aug 21, 2022 9:48 pm
So if I get into my car and start it with A/C set to auto and XX temp the blower motor will not come on, the rest of the unit acts like it's running, however if i then shut the hvac head unit off and back on...the entire system works perfectly fine (blower runs, cycles through all the speeds if set manually, ramps up and down properly in auto mode etc.) until I shut the car off, then wash rinse repeat...it's not a deal breaker/must fix now thing, but it is quite annoying on hot Texas days. Oh and it does the same thing in heating mode as well.
Things I have done:
1. Disconnect the batter for 1hr (no change)
2. hooked up with Autel and did test and calibration of A/C system and all actuators (no change - but mode actuator is sticking/not working correctly and is on order)
3. Swapped out hvac head unit with spare (working pull from old/other car) (No change).
So any ideas or am I just "lucky"? :roll:
P.S. To my knowledge I have no other electrical issues or gremlins with the car.
3.8L V6 SC, 180*T (Drilled),
Custom PCM w/Perf Shift,
SLP Ceramic Coated Headers,
Thrasher Cold Air Intake,
PostPosted: Fri Aug 26, 2022 5:43 pm
Yay, so it's just me...well if/when I figure it out, I'll report back (and probably change the title to match the issue).
PostPosted: Sun Aug 28, 2022 10:12 pm
Does it always act exactly this same way? Have you noticed erratic blower behavior over bumps?
PostPosted: Tue Aug 30, 2022 8:42 pm
Yup exact same way every time, no erratic blower behavior, all speeds work (once you turn it back on) manually or in auto mode...my first thought after ruling out the head unit was the blower control module (I believe these have a module vs a resistor IIRC), but I have no other signs of issue with it...it's just weird.
PostPosted: Tue Aug 30, 2022 8:45 pm
Does anyone have the GM "Description of Operation" for the HVAC system from GMSI? it might give me a clue as to what step in the operation I am missing (long shot I know).
PostPosted: Wed Aug 31, 2022 10:27 am
I'd replace the IPM as that is what actually is the brain of the system. The climate panel is just the display.
I've attached the Description of Operation as requested along with the blower motor schematic.
blower motor schematic.pdf [62.14 KiB]
Downloaded 90 times
Air Temperature Description and Operation.pdf [47.73 KiB]
Downloaded 72 times
Air Delivery Description and Operation.pdf [35.11 KiB]
Downloaded 89 times
PostPosted: Wed Aug 31, 2022 6:36 pm
Thank-you very much Andrew, I really appreciate that.
I am going to verify power's and grounds and continuity on the control wire from the IPM to the blower module as well as other functions of the IPM, to make sure nothing else (haven't noticed any) is DOA functionality wise.
Actually I did note one thing interesting. my Afterblow feature is turned on (I turned it on when I had access to a tech-2) and I know it will turn on for way longer than 4seconds...things that make you go Hmmmm :bhuh:
PostPosted: Thu Sep 01, 2022 11:06 am
JEFFSSSEI wrote:
...as well as other functions of the IPM, to make sure nothing else (haven't noticed any) is DOA functionality wise.
Quote:
The IPM functions include the following:
Ambient light sensor input and twilight delay input for headlights control.
Front HVAC air delivery and temperature controls.
IP dimmer switch input.
Ignition switch headlight control.
Interior lamps switch input.
Key-in-ignition switch input from the ignition switch.
Rear compartment lid release switch input.
Traction control switch input.
There are no new unread posts for this topic. Weird HVAC issue
bnvll2000
Thu Aug 10, 2017 10:15 am
bnvll2000 View the latest post
There are no new unread posts for this topic. Weird ELC Issue
gweg_b
Mon Dec 10, 2012 3:12 pm
gweg_b View the latest post
There are no new unread posts for this topic. Weird issue
terrancew3
Wed Sep 02, 2015 11:15 pm
There are no new unread posts for this topic. Weird suspension issue
SSEi95
Sun Jun 15, 2014 1:07 pm
Archon View the latest post
There are no new unread posts for this topic. HVAC issue
Cujo
Mon Oct 15, 2012 10:24 pm
Cujo View the latest post
Users browsing this forum: No registered users and 20 guests
