SUPERCHARGER NOSE REBUILD
londonontman
- SSEi Member
- Year and Trim: 1993 SSEi with full trim package
Does anyone have a part number for a rebuild kit for the M62 Eaton Supercharger off a 1993 SSEi. I fried mine and wrecker one has to much play.
AMSOIL EAO23 Oil Filter, Fram Platinum Air Filter, Royal Purple Synthetic 10W30- harofreak00
Re: SUPERCHARGER NOSE REBUILD
- Peterg22000
- Retired Moderator
- Year and Trim: .
1992 SSEi - Location: Toronto, Canada
did you fry the brearings, or just the coupler?
if you need a new nose drive, the wrecker one(going by your description) may still be good, just needing a new coupler..
2009 Phantom Metallic G8 GTS
Handling; XA Coilovers
12.9199 @ 106mph
1992 SSEi
londonontman
- SSEi Member
I blew outthe bearing right behind the pully.
AMSOIL EAO23 Oil Filter, Fram Platinum Air Filter, Royal Purple Synthetic 10W30- willwren
- Retired Admin
- Year and Trim: .
Moving to Forced Induction.
Make sure your bearing didn't spin in the housing (nosedrive) and ruin it.
All the M90 parts at Rolling Performance fit the M62.
londonontman
- SSEi Member
Thanks for the info. Actually when I got the supercharger off and removed the nose drive to see the bearing there was no more bearing there. There were only 7 intact ball bearings there and 4 partials. Lucked out that one of the mechanics I work with had a S/C off a 96 SSEi. The opening for the throttle body on the 96 S/C was smaller than mine which surprised me but the nose is exact. Going to order the rebuild kit and correct the problem. I checked the nylon bushing before reinstalling and there's no play.
The nose off a 96 SSEi is completely different from yours. He must have told you the wrong year.
- willwren
- Retired Admin
- Year and Trim: .
Toss the part. It isn't even close to compatible. It will not bolt up, not a single hole will align. The pins are different sizes, and the length (belt offset) is totally wrong.
Or take a pic of it, since your source doesn't seem to know what he's talking about, so we can identify it.
I want more details on the bearing failure. Where were the inner and outer RACES for the bearing? Did either break loose?
