new axle nut required?
widtrak77
- Year and Trim: 2000 Buick Park Avenue Ultra
1999 Bonneville SSEi
I'm doing a front wheel bearing on my '99 Bonneville. When I did CV axles on my Montana they came with a new nut and I used them, but I realized the new bearing didn't come with one. Is this not a torque to yield bolt? I don't think the FSM said to replace it.
- J Wikoff
- Year and Trim: 1992 SSE
Re: new axle nut required?
It is technically a one-use nut. I've replaced and I've reused them. Granted I haven't put thousands and thousands of miles on it since, but all seems well.
- nos4blood70
- Year and Trim: 2003 SLE
I've done like 8 wheel bearings on the front of my 2003 by this point. Including 3 passenger side axles. Still using the original nuts at almost 230k miles.
widtrak77
Maybe it's one of those cover our butts recommendations
- 95naSTA
- Year and Trim: 95 SLE
I'm going to say this only because it's not mentioned.. Make sure you torque it to spec so that the wheel bearing is preloaded properly.
dougtoth
- Posts like an LN3
- Year and Trim: 2005SLE CRIMSON
2005SLE PEARL
1975 MONTE CARLO - Location: MUSKEGO,WISCONSIN
Yes it is very important to torque that wheel bearing nut.
Torque is 118 ft.lbs.
I like to torque it with the vehicle on the ground so the full weight of the vehicle is on it.
Also I always use the same nut that I took off.
I will use the new nut when I replace the axle assembly.(nut is supplied with the new axle)
widtrak77
The FSM said 107 ft. Lbs I think I did 110.Should that be sufficient?
- nos4blood70
I've always seen 118 wherever I've looked so that's what I stick with.
Sadly, all the wheel bearings available are garbage, so get used to changing them if you plan on having the car for a while. I'm down to 15 minutes a wheel bearing at this point.
