Remote start and factory alarm don't like each other
sdxp787
Year and Trim: 2004 Bonneville SLE
Post by sdxp787 »
Guys, 2004 SLE, I had a remote start added to the car a few months ago. Shortly after ( same week), the remote start wouldn't work. After I would drive the car and then turn it off, it would work. What I concluded was that as long as I didn't use the lock switch on the doors, the remote would work.. but if I used the lock switch on the door to lock the car, the remote start would fail.. due to the factory alarm being set by locking the doors with the lock switch on the door... now, maybe that was a foolish assumption, I dunno... Now, being careful not to lock the car with the door lock switch and only using the remote, if the car sits for more than a day, the remote start fails. Now, it has gotten to the point that it almost never works, unless I drive the car and then it will start working. Does this have to do with the factory alarm? If so, how do I disable it? I get a message on my info center to have the alarm serviced.. what does that mean? The fact that my wife is driving the car and she hates being cold has driven me to get this fixed quick... the guy who installed the remote called the DEI tech center and they suggested it was the factory alarm but had no fix for it. I have seen the "Newrockies" website that has factory alarm bypasses, but not for this car..
96 SSEi
Re: Remote start and factory alarm don't like each other
Post by 96 SSEi »
do yourself a favour and bail on the remote - theft system is more important than comfort/laziness
yes, when you lock the car by switch or fob, the theft system will arm in 5 minutes. You're saying if you lock by fob, the starter works?
sdxp787
Post by sdxp787 »
When I use the remote start key fob, it will remote start... most of the time. If I lock it by the door switch, it definitely won't remote start. I am not sure if the installer used a passkey 3 bypass or not.
I don't think this car is high on the list of stolen cars in my area... I will take the comfort/laziness over security....
96 SSEi
Post by 96 SSEi »
have you tried unlocking with the gm fob? - I suspect that may work
I , have always been over- protective of my women, cars,money, and bike.I may lend money, but never the rest.
sdxp787
Post by sdxp787 »
car didn't come with a GM fob.
MKMike
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Post by MKMike »
You can buy fobs--either factory or aftermarket fobs that need to be programmed by the dealer, a locksmith or you if you own a Tech 2 tool.
Dorman makes a fob which includes the fob programmer and you can then program several fobs yourself.
The aftermarket fobs that I bought from Amazon sellers all have the same annoying flaw--which is that the trunk button isn't recessed enough; accidentally opening the trunk when you grab the keys is a regular occurrance.
Archon
Post by Archon »
I took my fobs apart, and put electrical tape over 3/4 of the foil for the trunk button. That stopped the accidental trunk opening, but it did require hitting the button "just right" to open it.
sdxp787
Post by sdxp787 »
Can we please get back to my topic?. I have a remote start that doesn't work sometimes because of the factory alarm. How can I disable the factory alarm?
MKMike
1998 SE
2001 SSEI
2002 SSEI
Post by MKMike »
sdxp787 wrote:Can we please get back to my topic?. I have a remote start that doesn't work sometimes because of the factory alarm. How can I disable the factory alarm?
No one went "off-topic".
It was suggested that you try a GM fob.
You replied that you don't have one.
I recommended ways to obtain one or more and program them.
Archon suggested a work-around for aftermarket fob trunk button sensitivity, in case you want to go that route.
What do you find irrelevant about this?
JEFFSSSEI
Post by JEFFSSSEI »
i believe he's stating it's off topic because the issue isn't with his actual fobs but rather an issue with the factory alarm system fighting with the remote start system.
SDXP787 could you post what remote start system you have...I'll see if I can look the wiring diagrams for the factory alarm and the remote start over and give you suggestions/ideas to check.
3.8L V6 SC, 180*T (Drilled),
Custom PCM w/Perf Shift,
SLP Ceramic Coated Headers,
Thrasher Cold Air Intake,
kc9dre
Year and Trim: '03 SLE Silver/Charcoal
Post by kc9dre »
IIRC you can order a PCM from Intense with this disabled or is that just for VATS? Which is for a previous generation again IIRC. That in itself is a $200 venture. before core return on your old PCM. Talk to Andrew at Bonnevilles Unlimited (Harofreak00) and he can get you 2 fobs and the module no programming required for much less...
I had an remote start on a '03 Town and Country once upon a time it had a transponder key and I have to have one of the keys mounted in a box up under the dash for the transponder to give the signal to allow the starter to engage. I would assume that PK3 is very similar in operation one would assume.
2002 SLE "Frankenbonnie" 02 engine, 04 transmission, and a 03 PCM to make everything talk. Sadly I know longer own
1993 Suburban Zombie Apocalypse Assault Vehicle (GMC Edition)
2003 Yukon Black/Charcoal cloth 4x4 POW/MIA
2003 SLE Silver/Charcoal (New Acquisition)
sdxp787
Post by sdxp787 »
Jeffssei, I will get that to you soon. In Canada on business now.
JEFFSSSEI
Post by JEFFSSSEI »
sdxp787 wrote:Jeffssei, I will get that to you soon. In Canada on business now.
ok, whenever's convenient for you.
I also found this: http://www.modifiedlife.com/2004-pontia ... er-wiring/
still double checking it's references vs actual schematics at the moment...will let you know if I see anything that stands out...a lot will depend on how sophisticated (for lack of a better word) your remote start system is.
ddalder
Post by ddalder »
You may or may not ever solve this problem. This is what happens when companies try to build aftermarket products and integrate them into a factory security system. I see that you have two options...
1. Try to pursue this and hope you come up with a solution, which may cost time, money and frustration.
2. Post the question to members asking which remote starters are KNOWN to work correctly in this car.
Lots of sales staff selling these things have little real-world knowledge of any specific car and will make promises that, while they believe to be true, are simply not.
I don't have a remote start in my Bonneville. Why? Because of exactly why you created this thread.
zamjohn
Post by zamjohn »
Have an 04 SE and have a remote start in it. Has always worked great as long as I use only the remote start fob. If I use GM fob in the mix it will go into alarm. Its at least 10 years old. It is an Astroflex fob and I believe made by Astrostart. All of these vehicles with PK ignition have to have PK compliant bypass module installed along with the remote start module otherwise they will not work. This is not difficult and any commercial installer would know this as the manufacturer of the remote start has these modules and provides the correct wiring diagram for this. I also have an Astro start starter in my Chevy truck, PK 3 I think it is and it is the same scenario there. The bypass module would be installed right near the remote start module. Most of this info can be found on the manufacturer website if it is a reputable company.
sdxp787
Post by sdxp787 »
The remote start is made by Directed and the model is 4103R
JEFFSSSEI
Post by JEFFSSSEI »
this is all I can find on it (below)... I can't seem to find schematics anywhere on their site or anywhere else for that matter.
http://support.directed.com/LearningCenter/DIY.aspx
