Fenderwell Intake?
Posted: Mon Mar 07, 2016 1:55 pm
by KnightBonne02
When doing a fender well intake do you guys remove the intake air temp sensor or adapt the intake hose
Re: Fenderwell Intake?
Posted: Mon Mar 07, 2016 3:47 pm
by Wes
Keep the sensor. If f you bought aFWI kit, it should have a location for the sensor.
Posted: Mon Mar 07, 2016 7:14 pm
by Jfridge92
+1, the kit from Intense Racing will come with a coupler to attach your throttle body to the intake, and it has a provision for the IAT sensor. Or, another option like I did (before my coupler dry rotted lol) is to get a normal coupler without a provision for the iat. Then get an iat extension harness from zzperformance, a small pvc breather filter, stick the iat in the breather, and zip tie the iat sensor and extension harness down into the fenderwell with the intake filter. Not that it'll make much difference either way.
Posted: Fri Mar 11, 2016 7:11 pm
by redzmonte
I drilled a hole in my FWI Pipe and installed a rubber PCV Grommet, then pushed it into the grommet.
You could also use a Syclone/Typhoon/Turbo Grand prix sensor that threads into the pipe (i did this on my Turbo LQ1 setup)
Grommet:
Threaded:
Posted: Fri Apr 01, 2016 7:40 pm
by KnightBonne02
Ok thanks guys
