Fenderwell Intake?
KnightBonne02
Fenderwell Intake?
Post by KnightBonne02 »
When doing a fender well intake do you guys remove the intake air temp sensor or adapt the intake hose
Never getting rid of my Bonnie
Wes
Re: Fenderwell Intake?
Post by Wes »
Keep the sensor. If f you bought aFWI kit, it should have a location for the sensor.
yourgrandma wrote:High
Jfridge92
Post by Jfridge92 »
+1, the kit from Intense Racing will come with a coupler to attach your throttle body to the intake, and it has a provision for the IAT sensor. Or, another option like I did (before my coupler dry rotted lol) is to get a normal coupler without a provision for the iat. Then get an iat extension harness from zzperformance, a small pvc breather filter, stick the iat in the breather, and zip tie the iat sensor and extension harness down into the fenderwell with the intake filter. Not that it'll make much difference either way.
Joseph
1999 Infiniti G20T - Sold
redzmonte
Year and Trim: 2000 SSEI
Post by redzmonte »
I drilled a hole in my FWI Pipe and installed a rubber PCV Grommet, then pushed it into the grommet.
You could also use a Syclone/Typhoon/Turbo Grand prix sensor that threads into the pipe (i did this on my Turbo LQ1 setup)
Grommet:
Threaded:
Shane "RedZMonte"
2004 Z16 Z06: Virgin
KnightBonne02
Ok thanks guys
