So i bought a kenwood and its just about ready to go in, but you clearly have to cut some plastics out in order to fit that
and the steering wheel control module.
If anyones already done this can you send a picture of the installation or how you cut the plastics and mounted everything
kind of stumped at this point because i dont want to take too much or too little off of the wrong places
rather keep it as conservative as possible
Making Space for aftermarket radio
djdani3l10
- Year and Trim: 2005 Pontiac Bonneville SE
- nos4blood70
- Year and Trim: 2003 SLE
Re: Making Space for aftermarket radio
Cut away little by little until it fits and make sure you don't cut any wiring. That's the only thing to worry about.
ddalder
Did you also get the module that produces warning chimes? This is also a function of the factory stereo so if you remove it you will no longer have them.
djdani3l10
yeah i got the metra wiring interface and the steering wheel control module.
now i just have to somehow fit them all in there, guess ill have to use trial and error.
ill take pictures and upload for anyone doing it into the future.
- nos4blood70
If it helps, I tucked away my steering wheel control adapter in the space underneath the center stack and in front of the shifter if that makes sense. Basically, underneath the heated seat/TC buttons.
I used the cheap harness that doesn't retain chimes, and I have a single DIN radio. Not sure what you have, but I ended up having to cut away less than I thought.
- Luxrain
- Posts like an LG3
- Year and Trim: Black 2003 Bonneville SLE
I have a double din that I didn't cut any plastic to fit. I have both modules.... I just stuck them in the hole to the left side and moved the plug for the antenna and harness back. Its suuuuper tight thought and will take some fiddling
2003 pontiac bonneville Sle with kenwood sound system. Upgraded tweeters, door speakers, deck speakers, kenwood sub and amp. Rage r20 18inch rims. Front and rear KYB shocks and struts. GXP Strut tower brace.. She's a work in progress still
