Super Bass (roof rattle)
pinstriper38
- LE Member
So I have a strange issue on my SSEi. At speeds varying between 30-35 mph, my headliner and roof vibrate, causing an obnoxiously loud bass sound in the cabin. It really does sound like I have a couple of 15's bumping in the trunk. The vibrations essentially turn the headliner into a giant speaker. If I open the sunroof those sounds get worse. At any other speeds, it still has slight vibration but not enough to cause an issue. Any idea what gives? Could some kind of vent be blocked somewhere?
- RJolly87
Re: Super Bass (roof rattle)
I would check tires and wheel bearings. I am thinking it's a resonance caused by another issue.
Are the windows shut when this is happening?
- haro1225
- Posts like a Northstar
- Year and Trim: 2004 GTO
I had a busted strut mount shake the car really bad like that, but it was at 55+ mph. Grab the wheels and give them a shake and see if they move, that would help narrow it down.
-Ryan
2013 Audi Allroad Quattro
yourgrandma wrote:Hi.
- MattStrike
- Year and Trim: '99 Montana
Another possibility is that the roof metal skin has separated from the structural bracing, if that's even possible. The roof should not be vibrating at all. Does windows open change it at all, +1 to Rjolly87 suggestion.
- RJolly87
It's funny you mentioned that, because I suspect I have that very issue in the PA. Sharp impacts or car wash blow dryers get pretty annoyingMattStrike wrote:Another possibility is that the roof metal skin has separated from the structural bracing, if that's even possible. The roof should not be vibrating at all. Does windows open change it at all, +1 to Rjolly87 suggestion.
pinstriper38
- LE Member
Windows open or closed seems to make no difference, aside from what I mentioned earlier when the sunroof is open, it gets worse. I think the struts are ok, I do know that my front drivers side wheel bearing is slowly on its way out. When I jacked the car up last I could wiggle the wheel ever so slightly in various directions. Would that really cause a resonance issue? Never associated that with a bad bearing, but it could make sense.
