4T65 Transmission Help/Question
1oldman
The '05 SE I bought in August of 2013 had 58K miles on it. It now has almost 81K miles. The transmission fluid had a nice pink/rose color to it. I had the fluid and filter changed in it as soon as I could. I wasn't too fond of how it shifted, I put some Lucus friction modifier in the transmission. It still didn't seem quite right so the youngest son installed a 4T65 TransGo shift kit in it. It made the transmission shift about 80% better. Since purchase, on two occasions, the transmission did not shift into 1st gear when we came to a stop at a signal. It did down shift into 1st when the gas was "stepped on" to go when the light turned green. The car does not have a SES light.
Question: what would be the best suggested course of action? Try and locate someone with a TechII to see if there are any transmission error codes, install a Transmission Solenoid Kit (http://www.ebay.com/itm/4T65E-Transmiss ... 2c6b3e4f0b), or ??
Thank you - BC
Thank you - BC
- nos4blood70
- Year and Trim: 2003 SLE
Re: 4T65 Transmission Help/Question
Did you come to a complete stop? The trans won't shift into first unless you coast below 10 mph, if you get what I'm saying.
SuperHbody
- SSEi Member
- Year and Trim: 1988 LE
How was it shifting that you didn't quite like?
- spoiledred94
- Posts like a Northstar
- Year and Trim: Black 2001 Bonneville SSEi
Did you get it flushed when you had the FF changed? It seems it could be gummed up journals. You could try an ATF cooler. I don't know if it would help but my 01 shifts much better cold
great car. Wrecked
Burnt Bonny.
great car. Wrecked
Burnt Bonny.
1oldman
Yes, we came to a complete stop. We had to wait for the light to change. - BCnos4blood70 wrote:Did you come to a complete stop? The trans won't shift into first unless you coast below 10 mph, if you get what I'm saying.
Besides the the times it didn't down shift into 1st, the transmission would be a little “soft” to shift is the only way I know how to describe it. I’m use to the way the 4T60E in the ’92 SSE shifts, and it just didn’t seem to shift as might be described as “confident” without being hard as the 4T60E. Sorry that I can’t describe it better. - BCSuperHbody wrote:How was it shifting that you didn't quite like?
I had the Cadillac dealer flush the transmission before I had the 4T65 TransGO shift kit put in and after I put in the Lucas friction modifier. - BCspoiledred94 wrote:Did you get it flushed when you had the FF changed? It seems it could be gummed up journals. You could try an ATF cooler. I don't know if it would help but my 01 shifts much better cold
SuperHbody
- SSEi Member
Well, I'm not a fan of putting "fix-it" from a bottle and I would venture that it'll cause more problems so I'd recommend getting that stuff out of there. Best course of action would be to monitor it would either a Tech2 or something like Torque Pro with an android OS. The only guess I would have is the solenoid sticking but I'm not well versed on automatics.
xcbullet
- SSEi Member
- Year and Trim: 2000 SE, transg kit & B&M trans cooler
Sounds like solenoid to me. They don't cost much but need to drop subframe & pull side cover to trans.
1oldman
I typically don’t use anything but Lucas, when I do use something. I’ve only used it twice before and had very good results with it. Most all the Lucas should be out as the Cadillac dealer flushed the system and a TransGo Shift kit installed after the Lucas was used. – BCSuperHbody wrote:Well, I'm not a fan of putting "fix-it" from a bottle and I would venture that it'll cause more problems so I'd recommend getting that stuff out of there. Best course of action would be to monitor it would either a Tech2 or something like Torque Pro with an android OS. The only guess I would have is the solenoid sticking but I'm not well versed on automatics.
As I “comprehend” it, the 4T65E has “quirks” not imparted to the 4T60E. I loved the way the 4T60E shifted in the old ’92 SSE.xcbullet wrote:Sounds like solenoid to me. They don't cost much but need to drop subframe & pull side cover to trans.
IIRC, someone on the FORUM did install new solenoid(s) in a 2000+ without having to drop the subframe, but I cannot find the post.
Is this the kit I should have installed if I go with solenoid(s)?
4T65E Transmission Solenoid Kit GM & Volvo Shift TCC EPC NEW 2003-On (99150)
http://www.ebay.com/itm/190777806603?ss ... 1436.l2649
Thank you - BC
xcbullet
- SSEi Member
Yes the lower left two are the shift solenoids. Good price for all that as if your in there u want to Change PCS too which I think is what they are calling the epc. I think that other tcc cost that much alone at Advanced auto.
1oldman
Any comments? I know it's an Impala, not a Bonneville, but how close does it come to applying to a Bonneville?
4t65e PCS Replacement, P1811, long shift, Chevy, GM PT1
https://www.google.com/url?sa=t&rct=j&q ... 1339,d.eXY
4t65e PCS Replacement, P1811, long shift, Chevy, GM PT2
https://www.youtube.com/watch?v=QgLSTyTd27s
4t65e PCS Replacement, P1811, long shift, Chevy, GM PT3
4t65e PCS Replacement, P1811, long shift, Chevy, GM PT4
https://www.youtube.com/watch?v=2xEuFj8wRp4
4t65e PCS Replacement, P1811, long shift, Chevy, GM wrap-up
https://www.youtube.com/watch?v=--ZJgZfIIhc
The "sanitation" of the tech drives me crazy. He should have cleaned the outside of the transmission case before removing it. I also think he should have put on clean gloves before handling/installing the new parts. The video's are extremely informative to someone like me that has never done this before.
Thanks - BC
Thanks - BC
- spoiledred94
Yeah BC get the dvd. I watched mine a dozen times before I did my rebuild. Would not have worked out the way it did w/o thank God.
great car. Wrecked
Burnt Bonny.
great car. Wrecked
Burnt Bonny.
1oldman
Unfortunately, it won't be me doing it. I'm lucky to get in and out of a car, much less work on one. My #1 mechanic got himself a full time job at a machine shop with benefits working 50 hours a week. I'll have to corner him when he's not tired and in a "good mood" - LOL! I watch the videos to be educated, or at least a semblance of it, when the car is worked on. - BCspoiledred94 wrote:Yeah BC get the dvd. I watched mine a dozen times before I did my rebuild. Would not have worked out the way it did w/o thank God.
