I went to raise it back up, and nothing nadda zip. I can hear the motor is working fine, and at the top of the switches travel I can SEE what looks like a silver PIN of some type. That pin goes up and down depending upon which way you run the switch.
I BELIEVE it's known as a "Window Regulator Guide" Here's the part I found at Rock, but wanted to confirm that's what the problem is before I get the part:
Rock Part # Dorman 74441.
From looking at it. There is a piece of plastic attached to the head of the pin, and that's what hooks onto the underside of the window and lets you raise and lower it am I right? If that's the case, the plastic head on it busted off and what I THINK I am seeing is the head of the regulator guide "pin" moving up and down on the inside surface of the window.
